Go to Post ...there is just something that I like about the smell of fresh engine oil... - Matt Attallah [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 26-01-2010, 19:35
vmuralidharan vmuralidharan is offline
FRC #2036
vmuralidharan is an unknown quantity at this point
Can the toughbox and axles support the entire robot
One of our drive configurations has the entire robot supported by the toughboxes and axles extending from those tough boxes.
The only problem was we aren't sure if the tough boxes can take all of that weight. If they can't, then we would have to go ahead and use sprockets and gears.
Our robot is aimed at going under the tunnel, however, so sprockets and gears means space we don't have. Hence direct connection is preferrable.
Unread 26-01-2010, 19:58
Michael Ogden Michael Ogden is offline
AKA: Rules Expert
FRC #0135 (Penn Robotics)
Team Role: Student
Michael Ogden has a spectacular aura aboutMichael Ogden has a spectacular aura aboutMichael Ogden has a spectacular aura about
Re: Can the toughbox and axles support the entire robot
The tough boxes can take the weight. The question is, will the boxes put you over 120 lbs?
Team 135 is attending Kansas City, Boilermaker, and hopefully Championship.
The preceding has been my opinion/advice/whatever, paid for with my $0.02.
Don't drink mt. dew after eating chili!
Unread 26-01-2010, 20:04
DonRotolo's Avatar
Back to humble
FRC #0832
It would be a best practice to not cantilever those output shafts, instead you should support the output shaft at the far end. If you do that, the shaft will support several times the robot's legal weight.
Unread 26-01-2010, 20:17
dtengineering's Avatar
AKA: Jason Brett
AndyMark has a long output shaft available as an upgrade option to the KoP toughbox unit that extends the output shaft by 3" or so.
We use that and support the outboard end of the shaft. It works great.
I don't know how the toughbox would do on a direct drive with the cantilevered load... it's not just the weight of the robot that you have to worry about, but also the tension in the chain... which, depending on the diameter of your sprockets, can become fairly significant. Add that to a bit of shock loading from a bit of looseness in the chain and... well... the toughbox can probably handle it, if your wheel and sprocket are mounted fairly close in, but I've never wanted to be the one to test that theory.
Jason
Unread 30-01-2010, 22:52
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
We have used the short shaft without any support. I did not want to do that but Andy said it would work fine. He was absolutely correct. You are only putting 1/4 of you weight on it. It should not be a problem. We are doing it again this year with Mecanum wheels.
Unread 30-01-2010, 22:57
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
If you mount the wheel next to the trans then the regular shaft if more that strong enough.
Connecting The Toughbox to the Robot Frame Video? baihooli3022 General Forum 1 16-01-2010 14:25
Support the Cybersonics at Barnes and Noble Dancin103 Fundraising 18 17-11-2009 18:53
Can the robot extend outside of the bumper zone. markulrich Rules/Strategy 15 08-01-2009 08:21
Can the music be continuous between the 30 seconds of animation and the credits? DinkyDogg 3D Animation and Competition 3 08-02-2006 23:55
Support Mike Wade and the NASA Field OZ_341 General Forum 5 25-11-2003 11:49
