Go to Post Don’t choose to aim for the stars because they mark the peak of our abilities, don’t choose to aim for the stars because it is easy, choose to aim for the stars because it shows the depth of our potential; choose to aim for the stars because it is hard! - Ken Leung [more]
Unread 31-01-2009, 17:59
DavidB DavidB is offline
FRC #2753
DavidB will become famous soon enoughDavidB will become famous soon enough
KoP Gyro and Accelerometer Placement
My question in regards to the KoP Gyro and Accelerometer. Basically I want
to know how close the center of the rotation of the robot do they need to be
to be accurate? Does it need to be dead center or can it be to the side at all?
Basically what is the optimal location to place them. Also is it best to have
them lower on the robot, at about drive train level? Thank you for any help you
can provide.
DavidB
Unread 31-01-2009, 20:28
Re: KoP Gyro and Accelerometer Placement
The accelerometer will falsely sense rotation as acceleration more strongly as it is mounted farther from the center of rotation of the robot.
The yaw rate sensor (gyro) will be increasingly inaccurate as centrifugal force from rotation affects its response.
Mounting the accelerometer higher will result in slightly less stable readings as the robot rocks.
We're mounting ours kind of low, reasonably close to the robot center line, near the rear of the robot.
Unread 31-01-2009, 21:02
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
It depends on what you're doing with them--our accelerometer is way off to the side, but the only thing we use it for is traction control and if we have enough traction to turn fast enough to affect the reading, we don't really need the traction control.
Another consideration is electrical noise--avoid putting it next to something that spits out a lot of EM(like the motors or PDU), as this can really noise up your readings.
Get yer robot source code here!
Unread 26-01-2010, 17:53
Wicked Wicked is offline
FRC #0354 (G-House Pirates)
Wicked is an unknown quantity at this point
So what would be a good gyro placement for detecting the angular position of the robot?
Our gyro's giving incorrect readings; for example, if we turn the robot 90 degrees, the gyro gives us 45.
Unread 26-01-2010, 20:55
The 2010 kit gyro has an output of 6 mv/deg/s. I believe the default value in the program is 12.5 mv/deg/s. You need to change the program to match the actual device you're using.
Last edited by Alan Anderson : 26-01-2010 at 23:17. Reason: put in a reference to the year so the next time this thread is resurrected it might not confuse people quite so much
Unread 04-02-2010, 22:49
DarKCroNo's Avatar
DarKCroNo DarKCroNo is offline
FRC #2670
DarKCroNo is an unknown quantity at this point
Should the sensors also be as parallel to the floor as possible? specifically the accelerometer?
Unread 05-02-2010, 09:18
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Yes. If either isn't parallel they will sense gravity as acceleration. This can be compensated for by setting the zero point with the actual at-rest readings. The gyro does this automatically on instantiation now.
Looking for extra Gyro and Accelerometer Redo91 General Forum 0 20-02-2008 22:56
gyro and accelerometer problems paulcd2000 Programming 6 16-02-2008 15:17
Filtering out Vibration while using a KOP Accelerometer joshyboy9987 Electrical 31 22-01-2008 08:20
Gyro/Accelerometer Drew Shapiro Programming 5 06-02-2006 22:44
