Go to Post If it gets people talking about not only robots but science and technology, it's all good. - Koko Ed [more]
Unread 26-01-2010, 18:29
Ratchet1's Avatar
Ratchet1 Ratchet1 is offline
THIS IS SPARTA!!!!
FRC #3062
Team Role: Student
Ratchet1 is an unknown quantity at this point
Exclamation Quick release switch
I was wondering if anyone knew where i could find a quick release switch. Our robot is using a foot to kick the ball under tension, and we need a way to draw back the foot. I was thinking that if we had a second arm that attached to the kicking arm with a quick release switch we could draw it back, and then release the switch to let it go. After the kicking arm was let go we could then have the switch arm swing back down to re-attach to the kicking arm and draw it back up.
Thanks,
Ratchet
Unread 26-01-2010, 20:16
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Quick release switch
A switch is an electrical device.
Search the forum for "gate latch"; beware that ones you buy may not be strong enough to be safe.
Unread 26-01-2010, 20:47
Ratchet1's Avatar
THIS IS SPARTA!!!!
FRC #3062
Team Role: Student
thanks. thanks for the term also, didnt realize "switch" was strictly an electrical term.
Unread 26-01-2010, 21:38
DonRotolo's Avatar
Back to humble
FRC #0832
Well, I guess a Railroad Switch is mechanical, but I think release mechanism might be better understood.
Also look at "Quick Release" things in a boating catalog. Might give you some good ideas.
Unread 26-01-2010, 22:02
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Try searching ratchet and pawl on www.mcmaster.com or the part number 6283K24.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Quick release Hastypickle Technical Discussion 18 13-01-2010 19:11
pic: Bike quick release part 2 falconmaster Extra Discussion 4 24-01-2008 07:39
Quick Vacuum Release Calvin_1631 Pneumatics 8 05-02-2007 20:49
Quick release wire harness mechanicalbrain Electrical 2 08-01-2006 15:36
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
