Go to Post Maybe between Art, skimoose, and some of the other intelligent folks on CD (most of us), we can force a redesign of the game.... - EricH [more]
Unread 26-01-2010, 23:01
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: Problem Loading Java Code
Java example code is wrong. Disable the watch dog at the top of autonomous and/or operatorControl. The disable of the watchdog in the constructor is cancelled out by code in the startApp method of RobotBase which is called after the instance is created but before autonomous or driverControl is called.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
problems loading code with Easy C Clayton Programming 1 31-01-2008 15:15
Loading Code Onto 2005 RC chris31 Programming 13 08-11-2006 07:45
Ways to speed up code loading process? Makubesu Programming 10 21-01-2006 17:23
Java headache problem MisterX Programming 8 30-03-2005 11:09
problem loading code with ifi loader psych0gambit Programming 7 25-02-2005 20:43
