Go to Post "automated chaos" nuff said. - Jferrante [more]
Unread 26-01-2010, 23:21
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Camera code
OK after finnishing the beta test and making sure all problems were cleaned up nicely i moved on to camera tracking with no success.
Can someone give me an accurate discription of what the default code does as far as tracking the ellipse?
P.S. the reason i am asking is because Reverse engineering the code helps me understand it better.
Unread 27-01-2010, 01:22
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Camera code
Have you looked at the white paper? http://joule.ni.com/nidu/cds/view/p/id/1568/lang/en
Unread 27-01-2010, 08:29
AKA: Jon
Re: Camera code
Yes I have read it and it tells me what the camera is supposed to be doing but not the motors and the gyro
is the gyro indicator from the dashboard supposed to be spinning round and round?
are the motors supposed to be lining up on the target?
Unread 28-01-2010, 19:21
Re: Camera code
Only if your robot is.
Only if you hold down the joystick button (trigger I think).
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
