Go to Post Both might accomplish the same "function" or "results" (perhaps a lift of some kind), but there are clear differences in simplicity, in cost, in maintainability, extensibility, and several other "ilities" -- which are a staple of engineering evaluation criteria. - msd [more]
Unread 26-01-2010, 17:58
screamingeagle screamingeagle is offline
FRC #1655
screamingeagle is an unknown quantity at this point
Question DEAD CRIO!!!!!
HELP!!! Our CRIO has died!!! Working fine one second, power down and now our CRIO is not working. We have power going to it, but no response from the board. Any Ideas???? NI stated that they don't have any in stock...now what do we do??????
Unread 26-01-2010, 18:02
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: DEAD CRIO!!!!!
did you press the e-stop button?
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 26-01-2010, 19:39
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: DEAD CRIO!!!!!
The E-Stop button's effect only works up until the point of power off. I would thoroughly test all connections between power, remove everything besides what's necessary.
I'm sure a veteran team could loan one if all else fails.
EDIT: Have you tried safe-mode?
Unread 26-01-2010, 20:07
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: DEAD CRIO!!!!!
Have you insured the battery you are using is charged?
Unread 26-01-2010, 22:45
joek's Avatar
Re: DEAD CRIO!!!!!
ask NI about it
Unread 26-01-2010, 22:53
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: DEAD CRIO!!!!!
I think it would help if you define "died" EDIT: ok you defined died
Do the lights come on?
Are the lights on and its just not responding?
Is it getting power/wired the right way? (The cRio runs on a special 24v circut)
Did someone hit the E-Stop/Is the E-Stop button plugged in?
Is the code "Enabled" on the driver station?
Did someone rub their feet on the carpet and zap it?
I'd say check that its getting power, and try re-imaging it.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 26-01-2010, 23:30
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: DEAD CRIO!!!!!
first of all,
i had a similair problem last year,
the Power distribution board (PDB) showed that the cRio was receiving the 24v it requires with the led light, so it looked alright... but it still didnt power up the cRio.
solution: make sure your battery has more than 12v available... i believe mine was registering about 9.9v when the cRio didnt start up.
the PDB's led's are helpful, but not 100% accurate. change your battery to a freshly charged one,
make sure all connections are good! if a positive wire touches your cRio case, it will be dead for good
Unread 26-01-2010, 23:42
J_Beth J_Beth is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
J_Beth will become famous soon enoughJ_Beth will become famous soon enough
Re: DEAD CRIO!!!!!
We thought that ours had died the other day also. When we powered up, the lights on the Power distribution board came on, as did the lights on the Jaguar's, and the Wireless bridge. But the lights did not come on the CRio. As it turns out we just had a very low battery. Try replacing that and see if that works.
"I Wanna Be A Robot Maker!!!!"
Unread 27-01-2010, 09:28
FRC #1655
Re: DEAD CRIO!!!!!
Thanks to everyone for the replies. It was a battery problem....even though our distribution board stated that we had 12V coming through. We even metered the wires going into the CRIO and found voltage, I guess it just wasn't enough.
If you need answers...CHIEFDELPHI has them!!!!!!!! THANK YOU
Unread 27-01-2010, 10:07
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
Re: DEAD CRIO!!!!!
Yeah, keep thoose batteries charged. Our programming team has been using the same battery since Kickoff for testing the cRIO and it finnally got too low yesterday (Yeah, it really lasted that long - no motors but still amazing) XD cRIO starts getting angry around 10.8 v.
~DtD
Unread 27-01-2010, 11:57
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: DEAD CRIO!!!!!
It can be a very good idea to put someone in charge of the batteries. Ensure that dead batteries are always being charged, that the robot has a fresh one when you get started each day, and that the batteries are changed out on a regular basis. The last thing you want to do is kill a battery only to find out none of the rest are charged, especially if it's getting near ship and you're trying to test the robot!
Unread 27-01-2010, 13:13
joek's Avatar
Re: DEAD CRIO!!!!!
and don't drive a slick-wheel robot on a springboard floor- we did that last year and fried 2 crio modules by way of static build up on our robot
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
Dead cRIO??!!? HELP!!! naruto137 Technical Discussion 11 05-02-2009 23:58
Dead DS viper110110 FRC Control System 2 24-01-2009 10:02
Dead RCX.. bubis Lego Mindstorm Discussion 19 31-05-2005 00:48
Dead OI Smrtman5 Control System 1 30-10-2004 00:39
