Go to Post *puts on flame suit and goes to hide in the corner* :D - Wayne Doenges [more]
Unread 26-01-2010, 23:29
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Gear Specifications
3132 here,
Hey everyone. It's time to belt down and start designing the kicking mechanism. I'm planning to use the Fisher Price motor with another gear to pull back some surgical elastic.
We're hoping that the other gear is at least 3-4" in radius. We have people who might be willing to machine some for us, but I've got no idea on how I'm going to provide them the right specifications for the machining process.
Is there any software that can help me in this process?
Unread 26-01-2010, 23:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Gear Specifications
Instead of using one big gear, how about using a few small gears? The gears that come in the plastic transmission are designed to work with the motor, after all.
Unread 26-01-2010, 23:37
Our mechanism doesn't work like that. It's necessary to use one big gear.
Unread 26-01-2010, 23:46
MrForbes's Avatar
AKA: Jim
Another approach could be to use a large sprocket, and one stage of the FP gearbox. We did something similar last year.
this is the gearbox we made, using two sheets of aluminum, some hex shaft, two bearings, and one gear from the FP gearbox. The second plate is not shown, nor is the plywood spacer.
here is the gearbox driving a larger sprocket with a chain.
I don't know if this idea will help you, but it could be easier to find a premade pair of sprockets, than to get a gear machined?
Unread 27-01-2010, 00:06
Does the chain fit nicely on the FP motor or will I have to make modifications?
Unread 27-01-2010, 00:07
MrForbes's Avatar
AKA: Jim
The chain will not fit on the motor, you'll need to make a shaft to fit into an FP gear, and then get a sprocket to fit on that shaft.
Do you have the speed/torque aspects of the design figure out yet?
Unread 27-01-2010, 00:48
My current design would output 1.35Nm (0.995707395 lbf/ft) of torque at 1250RPM from the big gear. The FP motor would be spinning at 7500RPM at 225mNm (0.165951232 lbf/ft). Would 1.35Nm (0.995707395 lbf/ft) be enough to pull back the surgical elastic?
Arbor Press Specifications JesseK Technical Discussion 7 24-06-2008 15:10
Field Rug Specifications MaddyW Rules/Strategy 1 21-01-2006 17:44
Specifications TechnocratiK Programming 2 14-12-2005 16:48
Dashboard Interface Specifications archiver 2000 11 23-06-2002 22:43
Dashboard Interface Specifications archiver 2000 1 23-06-2002 22:42
