Go to Post Friction is finicky. - Ether [more]
Unread 26-01-2010, 23:35
JohnCushion's Avatar
JohnCushion JohnCushion is offline
AKA: Now
FRC #0190 (Gompei & The HERD)
JohnCushion is an unknown quantity at this point
Re: How do omni wheels work
The "omni" wheels are indeed just like a castor, but they are more stable with side loads then the shopping cart variety. They allow you to turn about the center of your drive wheels. DO NOT try to power them, because they do not operate well in that manner.
If you are looking to go forward, back, sideways and round and round, look into Mechanum wheels.
Here is an example of them in an industrial application: http://www.youtube.com/watch?v=CjcyHicm3NA
AndyMark sells a 6" and an 8" version as well.
There are some issues with them, such as a certain level of finesse needed in the coding of the robot and each wheel needs individual power in order for them to operate properly. They also do not do well when one of the wheels is lifted off the ground. You may also want to look into using a gyro to maintain a certain orientation of the robot as well.
Hope this all helps and good luck with the rest of build season.
How do you wire the inputs for holonomic drive (omni wheels) star_lancer NI LabVIEW 8 22-01-2010 22:29
caster wheels vs. omni wheels gondorf Kit & Additional Hardware 4 23-01-2008 22:45
How Do Mecanum Wheels Work? SPARKY1688 Kit & Additional Hardware 9 08-01-2007 23:39
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Omni Wheels edomus General Forum 6 06-02-2004 13:35
