Go to Post The first law of programming is that there are always ways of doing things quicker and in less space than you already are. - jgannon [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 23-01-2010, 16:43
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
Compressor Code causes No Robot Code Error
I've just tried to add the Compressor class code to my C++ Iterative Robot code and when I load it to the robot it causes a no robot code error. Has anyone else run into this problem and do you have a solution on how you fixed it.
The code I used was:
public:
 * Constructor for this "IterativeRobotDemo" Class.
 * Create an instance of a RobotDrive with left and right motors plugged into PWM
 * ports 0 and 1 on the first digital module.
	IterativeDemo(void)	{
		cout << "IterativeDemo Constructor Started\n";
		// Create a robot using standard right/left robot drive on PWMS 1, 2, 3, and #4
		myRobot = new RobotDrive(1, 3, 2, 4);
		// Define joysticks being used at USB port #1 and USB port #2 on the Drivers Station
		rightStick = new Joystick(2);
		leftStick = new Joystick(1);
		// Acquire the Driver Station object
		ds = DriverStation::GetInstance();
		dsLCD = DriverStationLCD::GetInstance();
		// Counters to record the number of loops completed in autonomous and teleop modes
		auto_periodic_loops = 0;
		disabled_periodic_loops = 0;
		tele_periodic_loops = 0;
		//Compressor Instance
		Compressor *cpressor = new Compressor(1,1);	//Input DIO Port 1, Relay 1
		cpressor->Start();	//Start compressor
I have the compressor Spike wired to Relay 1 and the Pressure Switch wired to Digital Input 1. Would I get a no robot code error if something wasn't physically connected right? The example in the User Guide said to put it in the constructor of the robot and that's the only place I need it, which I have done.
The robot works fine without the compressor code, its just when I uncomments the line above.
Any ideas? Help.
Unread 23-01-2010, 19:39
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Compressor Code causes No Robot Code Error
Are you getting any errors in the diagnostics tab of the driver station? Is your robot program crashing?
Unread 24-01-2010, 10:33
sircedric4's Avatar
AKA: Darren
I didn't realize we got error messages on the driver station. I will check that and get back to you.
Unread 25-01-2010, 17:41
sircedric4's Avatar
AKA: Darren
All right, I do get an error message on the computer. Here is what it says:
No change to network configuration "Local Network Connection"
I/O Unit not detected or not installed correctly
I thought this might have meant that I had a wire crossed or a bad PWM cable, but I have completely replaced the PWM cable and checked it to make sure it didn't have a short. The robot works perfectly fine if I don't call the Compressor code.
I am running the switch to the white and black cables in the PWM bundle just like last year. I am installing it in the digitial input on my digital sidecar, in address 1.
For the Spike I am running it to Relay 1 on the digital sidecar.
I believe I got it all wired right, but yet I still get the No Robot Code error and it appears it is "crashing".
Help please, I don't have the slightest clue what's going on here.
Unread 25-01-2010, 17:50
Can you post a console log of the crash?
Unread 25-01-2010, 18:40
sircedric4's Avatar
AKA: Darren
So I have put Compressor on the back burner while we wire up and work with the encoders and now I get the same exact thing with them as I was getting with the Compressor. I am posting my code, can someone help me figure out what I am doing wrong. I imagine its to do with code or not activating something properly, but I am willing to try other things if you got ideas.
#include <iostream.h>
#include "WPILib.h"
#include <taskLib.h>
#include "DashboardDataFormat.h"
 * This is a demo program showing the use of the IterativeRobot base class.
 * The IterativeRobot class is the base of a robot application that uses similar control
 * flow to that used in the FRC default code in prior years.
 * This robot provides identically the same external behavior as the SimpleRobot demo program.
 * This code assumes the following connections:
 *   Driver Station:
 *     Joystick 1 - The "right" joystick.  Used for either "arcade drive" or "right" stick for tank drive
 *     Joystick 2 - The "left" joystick.  Used as the "left" stick for tank drive
class IterativeDemo : public IterativeRobot
	// Declare variable for the robot drive system
	RobotDrive *myRobot;			// robot will use PWM 1-4 for drive motors
	// Declare a variable to use to access the driver station object
	DriverStation *ds;				// driver station object
	DriverStationLCD *dsLCD;			//driver station LCD update
	// Declare variables for up to three joysticks being used
	Joystick *rightStick;			// joystick 1 (arcade stick or right tank stick)
	Joystick *leftStick;			// joystick 2 (tank left stick)
	//Encoder setup
	Encoder *leftencoder;
	Encoder *rightencoder;
	//Compressor
	//Compressor *cpress;
 	// Local variables to count the number of periodic loops performed
	int auto_periodic_loops;
	int disabled_periodic_loops;
	int tele_periodic_loops;
	int dash_periodic_loops;
public:
		//cpress = new Compressor(3,1);	//Input DIO Port 1, Relay 1
		//cpress->Start();	//Start compressor
		//Encoder Instances
		leftencoder = new Encoder(9,10,true,Encoder::k4X);
		rightencoder = new Encoder(11,12,true,Encoder::k4X);
		cout << "RobotDemo Constructor Completed\n";
	/********************************** Init Routines *************************************/
	void DisabledInit(void) {
		disabled_periodic_loops = 0;			// Reset the loop counter for disabled mode
	void AutonomousInit(void) {
		auto_periodic_loops = 0;				// Reset the loop counter for autonomous mode
	void TeleopInit(void) {
		tele_periodic_loops = 0;				// Reset the loop counter for teleop mode
		dash_periodic_loops = 0;
	/********************************** Periodic Routines *************************************/
	void DisabledPeriodic(void)  {
		// feed the user watchdog at every period when disabled
		GetWatchdog().Feed();
		// increment the number of disabled periodic loops completed
		disabled_periodic_loops++;
	void AutonomousPeriodic(void) {
		// feed the user watchdog at every period when in autonomous
		auto_periodic_loops++;
		if (auto_periodic_loops == 1) {
			// When on the first periodic loop in autonomous mode, start driving forwards at half speed
			myRobot->Drive(0.5, 0.0);			// drive forwards at half speed
		if (auto_periodic_loops == 200) {
			// After 200 loops (2 seconds given 10ms loops), stop the robot
			myRobot->Drive(0.0, 0.0);			// stop robot
	void TeleopPeriodic(void) {
		// increment the number of teleop periodic loops completed
		tele_periodic_loops++;
		dash_periodic_loops++;
		// determine if tank or arcade mode; default with no jumper is for tank drive
		myRobot->TankDrive(leftStick, rightStick);	 // drive with tank style
		//Dashboard update
		if (dash_periodic_loops >= 20) {
			sendIOPortData();
			dsLCD->Printf(DriverStationLCD::kMain_Line6,1,"Code 6:");
			dsLCD->Printf(DriverStationLCD::kUser_Line2,1,"Left encoder: %d",leftencoder->Get());
			dsLCD->Printf(DriverStationLCD::kUser_Line3,1,"Right encoder: %d",rightencoder->Get());
			dsLCD->UpdateLCD();
/********************************** Continuous Routines *************************************/
	 * These routines are not used in the imitation of the SimpleDemo robot
	void DisabledContinuous(void) {
	void AutonomousContinuous(void)	{
	void TeleopContinuous(void) {
START_ROBOT_CLASS(IterativeDemo);
I can't see anything wrong with the code, but I don't know what else to do. If I comment out the encoder code and the compressor code it works fine. Anyone know what's going on? Am I doing pointers or something wrong?
Unread 25-01-2010, 20:41
sircedric4's Avatar
AKA: Darren
I will look up how to do this and see if I can't get a console log tomorrow evening. Does someone have a cliff notes version of how to get that console log?
I did some searching this morning and found the NetConsole thing which I will try first, but since everything I try this year has been an abject failure from the beginning I also want to have the serial cable console procedure on hand as a backup. The problem is that I can't find directions for it. I've searched Chief Delphi and found some stuff about last years documents with instructions, but that link to last year's control system documentation has been convienently broken by FIRST.
I do know I need a null-modem adapter which I will pick up on the way to the school and to use HyperTerminal but I don't know much more about how to setup the program to chat with the cRio. I looked in all the documents for this year with no luck. Could someone point me to the Hyperterminal instructions for the cRIO and also let me know if you've had any trouble with NetConsole I should be aware of.
I really want to solve this problem soon, so I want to have every tool at my disposal tonight when I try to get this error message from the console so I can get some help.
Last edited by sircedric4 : 26-01-2010 at 07:30. Reason: searched, still need help
Unread 26-01-2010, 18:17
sircedric4's Avatar
AKA: Darren
Ok, you've got my code up above and we got NetConsole to work right off the bat today which was a pleasant surprise. We did have an interesting glitch today. When we turned on the robot we got the same No Robot Code as usual with the new code, but after the computer went to standby and we tried it a little later it started to run. It did not give me encoder data, but it got past the crash. We tried it a little later and it was back to No Code. I don't like intermittent stuff.
Here's the error stuff from our console: I couldn't find a way to actually cut and paste the actual text so had to take screenshots. It is in the attachment.
Hopefully this is enough info to help us, we are spinning our wheels here.
Unread 26-01-2010, 21:05
See this thread and look for the information on using mlongcall.
Unread 27-01-2010, 00:44
Well... I'm glad something is working for you!
To copy text from NetConsole client, just select it. When you let go of the left mouse button, it is copied to the clip board. To paste, just click the middle mouse button in the window. You can also resize the window to make it show more text or even maximize it.
And like Alan said... you need to build with the mlongcall option. Any project you create from the examples should already have this option set for you. Did you create a new project from scratch or based on an example? If an example, which one... I'd like to fix the example if one is not configured to use mlongcall.
-Joe
Unread 27-01-2010, 00:49
You need to configure HyperTerminal (I prefer PuTTY for serial terminal) for 9600 baud, 8bit, no parity, 1 stop bit, no flow control. You need to flip the CONSOLE OUT dip switch on the cRIO to ON (push down away from the outside edge) and reboot the cRIO. Connect with a null modem cable, and you should be up and running with serial console. Remember that you need to disable NetConsole (remove it from the ni-rt.ini startup) if you want the global stdio to show up on the serial port.
-Joe
Unread 27-01-2010, 06:59
sircedric4's Avatar
AKA: Darren
-Joe
We built it off the IterativeRobot example. But when I was copying that and pasting it and changing the name to our version control it wasn't taking information from the new directory so I was deleting the old build targets and creating new build targets. Could that have removed the magic "mlongcall" thing?
I swear I am starting to feel like a caveman looking at magic. Any sufficiently advance technology being indistiguishable from magic. I feel like I am learning a specific chant to get specific outcomes. I'm glad we got wizards here that I can at least get answers on which magic chant to do for any given outcome. Thanks guys. I'll setup the project like outlined above and let you know if that solves our problems.
Unread 27-01-2010, 08:10
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Could be, but I doubt it.
I'm pretty sure I created that same sample project and, with no tinkering or mucking around, there was no -mlongcall in the compiler switches.
Easy enough to create a new one, you can create as many projects as you want from the samples, and have a look.
Why did you create new build targets? Just curious.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 27-01-2010, 12:24
sircedric4's Avatar
AKA: Darren
Everything started fine. We would create the initial template and then before we added code to it, I would copy the project and repaste it to the explorer and rename it and would create me a new folder to change the code in. This was working great up to Code 5, when we then copied it to move on to Code 6, whenever it would do the linking for the newly compiled 6 code, it kept pulling the data from the old 5 code and the code on the robot wasn't changing right.
So now we copy the project, and then remove the build target and build a new target and the code always links and runs correctly. I guess I could just move the appropriate .cpp files over to a new created template project each time but the procedure I highlighted seemed easier. I wasn't sure that it might not be causing the mlongcall problem which is why I mentioned it.
Hopefully we'll be up and running again tonight when I get the mlongcall in.
Unread 27-01-2010, 16:59
Just to be clear, you are referring to the "FRC Default Program" (as listed in the examples) aka "BuiltinDefaultCode" (as listed in the Project Explorer)? I double checked this project and it definitely includes the -mlongcall option.
I tried removing the build targets and creating a new one and it still had the -mlongcall setting there.
I swear I am starting to feel like a caveman looking at magic. Any sufficiently advance technology being indistinguishable from magic. I feel like I am learning a specific chant to get specific outcomes. I'm glad we got wizards here that I can at least get answers on which magic chant to do for any given outcome. Thanks guys. I'll setup the project like outlined above and let you know if that solves our problems.
I know it seems like witchcraft, but it really is just an option for the PowerPC platform that can save space if your code is not huge. WPILib is huge... well... huge enough to need longcalls. We anticipated this issue and made it use the whole memory space by default. Really what we need to track down is how you lost that option in your project.
-Joe
User code won't download/run-possible causes? nathanww C/C++ 3 21-01-2009 11:00
Code error causing robot to go into programming mode. MJD Programming 14 30-10-2007 14:21
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
Compressor Code gacp Programming 2 19-02-2005 16:18
