Go to Post It's always better to figure out why a design actually works and the best ways to implement it than to just assume upgrading to a "better" material will make everything work. - Cory [more]
Unread 27-01-2010, 02:02
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Changing Crio Digital Sidecar input slot from slot 4 to 5
Originally Posted by Trevor_Decker View Post
Is their a way to reference a Jaguar/victor when you are calling RobotDrive(I did not see one in the javadocs)?
When you construct it, you can pass in Jaguars that were constructed for slot 6...
Jaguar left = new Jaguar(6, 1);
Jaguar right = new Jaguar(6, 2);
RobotDrive drive = new RobotDrive(left, right);
-Joe
Unread 28-01-2010, 12:29
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
The reason you can't use only slot 6 is the Robot Signal Light only works on slot 4.
1 Open Slot for BattleCry WernerNYK Off-Season Events 1 09-06-2007 12:26
Need one more fuse slot Guru Electrical 5 16-02-2007 17:51
T-Slot extruded aluminum blue_crew Technical Discussion 18 29-01-2006 13:05
One Slot Left... Joe Johnson General Forum 7 16-10-2001 14:56
