Go to Post Imagination is important, but try not to use it as a substitute for actual information. - Alan Anderson [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 27-01-2010, 08:10
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Compressor Code causes No Robot Code Error
Originally Posted by sircedric4 View Post
We built it off the IterativeRobot example. But when I was copying that and pasting it and changing the name to our version control it wasn't taking information from the new directory so I was deleting the old build targets and creating new build targets. Could that have removed the magic "mlongcall" thing?
Could be, but I doubt it.
I'm pretty sure I created that same sample project and, with no tinkering or mucking around, there was no -mlongcall in the compiler switches.
Easy enough to create a new one, you can create as many projects as you want from the samples, and have a look.
Why did you create new build targets? Just curious.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
User code won't download/run-possible causes? nathanww C/C++ 3 21-01-2009 11:00
Code error causing robot to go into programming mode. MJD Programming 14 30-10-2007 14:21
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
Compressor Code gacp Programming 2 19-02-2005 16:18
