Go to Post There's a stark difference between bragging and taking pride in your work. While "Ha ha! We're better than you! We won seventeen regionals and you didn't!" would clearly fall in the former, listing your achievements would definitely fall in the latter. - artdutra04 [more]
Unread 20-01-2010, 16:35
Eric891 Eric891 is offline
FRC #2729
Eric891 is an unknown quantity at this point
Plaction Roughtop Tread on carpet
For our robot this year, we are planning on using the Plaction 8" roughtop tread wheels. The tread design will provide good traction on the carpet.
The concerns we have are:
Utilizing tank drive, when turning, will the tread get caught in the carpet?
Will turning put too much stress on the CIM motors?
Thanks so much for your advice!
Unread 20-01-2010, 16:38
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Plaction Roughtop Tread on carpet
Describe the drive layout you are planning to use. The more info the better.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 20-01-2010, 16:43
More specifically, how many wheels you have on the ground, how many of them are powered, are any of them "dropped", and "wide" configuration vs. "narrow" configuration are good items to include when asking a question like this.
Unread 20-01-2010, 16:47
FRC #2729
We are using a tank drive system with 4 wheels on the ground. One CIM motor powering each side. Narrow configuration.
I apologize for being so broad, and I appreciate the guidance!
Unread 20-01-2010, 16:51
Jared Russell's Avatar
Taking a year (mostly) off
The layout you described will likely have major problems when turning.
There is a good white paper on this topic: http://www.chiefdelphi.com/media/papers/1443
Things that you can do to improve your turning ability:
- Put the wheels closer together (front to back)
- Add middle wheel(s) and lower them slightly to shorten your effective wheelbase
- Replace one pair of wheels with lower friction wheels
Unread 21-01-2010, 16:22
acidrain2012's Avatar
acidrain2012 acidrain2012 is offline
FRC #0393 (Full Metal Jackets)
acidrain2012 is an unknown quantity at this point
Our team is planning on using plaction wheels up front and omnis in the rear to provide a good turning circle and good traction. We are using good old fashioned tank drive.
Three Schools
One Team
Big Dream
Unread 21-01-2010, 21:50
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
We've used a similar design (IFI High Traction instead of Plaction) for years with excellent results. In our early days we used 4-wheel skid steering as you initially described, and went through batteries in just under 2 minutes.
"It's NOT Just A Robot Thing!"
Unread 25-01-2010, 06:53
Tony.Wu Tony.Wu is offline
Carnassial
AKA: Dave The Mechanic
Team Role: Animator
Tony.Wu is an unknown quantity at this point
Send a message via MSN to Tony.Wu
Hi 3132 here
We have 2 plaction wheels in the center for drive and 2 plastic wheels on each end (front and back). We are also using 4 CIMs to give us the torque we need for those plactions to turn
Unread 26-01-2010, 19:04
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
a cheaper solution is to buy 8" RC wheels, cut the tread off, slice them up, and zip-tie them to a KOP wheel, we did something similar for our shooter last year
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 26-01-2010, 19:22
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
We are currently using a 3/32 drop on the 4 center wheels of an 8 wheel west coast drive and turning is fine.
Unread 26-01-2010, 19:33
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
How far apart are your two center wheels?
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 26-01-2010, 23:25
Expect high currents in the CIMs and possible low battery voltage at the end of the match. Please try the robot on carpet before you make a final decision. If you don't have a practice field take the robot into the library, theater or any place with a lot of carpet and practice turning.
Unread 26-01-2010, 23:30
waialua359's Avatar
AKA: Glenn
All 4 wheels on each side are 9.60 inches apart from each other, using 8" wheels, with the 2 centers dropped.
Unread 27-01-2010, 08:20
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I can say that the 2 omnis/2traction 4WD tank steering is actually really nice. We ran it in 08 and it handled perfectly and was super simple.
Although, we had about 75% of our weight on the traction wheels, where more likely teams this year will be fairly evenly spread out.
Unread 27-01-2010, 10:51
Were you using dual omnis wheels with offset rollers, or just single omnis?
AndyMark Plaction Wheels Diserasta Technical Discussion 1 17-01-2010 22:20
Plaction Wheels : 250 Spacers/Review Ice Berg General Forum 2 17-01-2010 11:26
andy mark plaction wheel gorrilla Technical Discussion 2 05-10-2008 15:25
Black Roughtop Rob Colatutto Technical Discussion 13 17-04-2007 18:29
