Bah. 130 makes it a challenge. If it is raised to 150, it won't be hard to do whatever you want. Remember, this stuff is teaching you how to do it in real life. 130lbs is a great limit. You build what you think you can in that weight limit. If you're over, drill some holes or get rid of something. If you're under, you can add some weight (or just leave it alone). Also, better materials doesn't neccisarily mean better robot
(As for getting kicked off for doing the white boy dance...haha...maybe they had good reason  )
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
