Go to Post you don't need a fancy workshop to build a good robot, just determined people. - pacoliketaco [more]
Unread 27-01-2010, 09:29
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Driver Station not displaying Battery Voltage
Has anyone had trouble with getting the battery voltage to show up in the Driver Station?
I have installed the jumper on the Analog Bumper in position 8, but am still getting no display in the DS.
I put a jumper on position 1, just to try it and the indicator in the Dashboard shows it is there, so I know the IO is being read.
We're stumped. Any ideas?
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 27-01-2010, 10:33
Doc Wu's Avatar
AKA: Al Gritzmacher
Re: Driver Station not displaying Battery Voltage
Answering my own question:
After some digging, I found out my mistake.
The jumper goes on the 3-pin DIP header at the end of the Analog Breakout, not on the input pins for Input 8. I'll have to try it when I get back to the school to confirm, but I'm pretty certain this will solve my problem. Well at least THAT problem.
I should have just walked over to last year's robot and looked at it!
FRC Control System Data Sheets (Page 11)
Unread 27-01-2010, 11:43
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
That was going to be my advice ... to NOT install the jumper on the input pins of the breakout ... but on 2 of those 3 pins in the upper corner of the board.
I'm also not near my 'bot, so I'm not sure which 2 ... but once you short them with the jumper, then you shouldn't wire anything up to input 8 on that breakout.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 27-01-2010, 13:24
It's the outer two pins on the Analog Breakout in the first module slot that need a jumper.
But you'll see that from last year's robot.
Unread 23-02-2010, 13:20
lucoytoa's Avatar
lucoytoa lucoytoa is offline
Programmer
AKA: Nicolas Xiong
FRC #2276 (STARS of Cypress)
lucoytoa is an unknown quantity at this point
Can someone send me a picture of the jumper? I can't find one.
Unread 23-02-2010, 13:29
Look at the bottom of Page 14 of the Kit of Parts Checklist. It's a tiny thing, somewhat less than a quarter inch square.
Unread 23-02-2010, 15:34
Doc Wu's Avatar
AKA: Al Gritzmacher
Also, if you've ever configured a computer hard drive, it's just like the jumper that sets master/slave settings.
There was a plastic bag in the KOP with a few of them. This year's were white, in the past they have been black, but the color doesn't matter. If you can't find them, Radio Shack used to sell a package of them as well.
In an emergency, you could clip an end off a PWM cable and strip two of the wires (Center and one end) and twist them together to do the same thing.
Unread 23-02-2010, 16:03
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
Here is a picture of 2 jumpers on a board (not a FIRST board, just a random Google search)
I just circled one of the jumpers (and the pin next to it), if that helps at all.
Driver Station/Control System not Communicating dekker120 FRC Control System 6 12-02-2009 09:48
Displaying battery info on driver station koo_04 NI LabVIEW 1 07-02-2009 18:44
Driver station and battery fail to communicate Peter H FRC Control System 0 05-02-2009 15:11
Reading battery power on Driver station. Digmaster Electrical 8 31-01-2009 20:09
Driver Station Not Updating elbuo FRC Control System 8 13-01-2009 18:39
