Go to Post FIRST is the only sort of competition that I've seen where somebody can win and the opponents can be genuinely happy for them. - RiceRobotica [more]
Unread 27-01-2010, 10:02
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Re: Labview Joystick Input Example code not working
jsprigg,
We're having the same issue. I posted it under title
"HELP!! No readouts anywhere on dashboard"
Have gotten a couple of responses. Take a look and see if any help you guys out. We're going to try them as soon as I get a programmer in my classroom. Can't for the life of us figure out what's going on either.
Best of luck and if we figure out our problem I'll shoot you a message letting you know what our solution was. Would appreciate the same...
Robyn
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 27-01-2010, 10:26
jsprigg's Avatar
jsprigg jsprigg is offline
Mad Scientist
AKA: Jeff Sprigg
FRC #1547 (Where's Waldo?)
jsprigg is an unknown quantity at this point
Send a message via ICQ to jsprigg Send a message via AIM to jsprigg Send a message via Yahoo to jsprigg
Originally Posted by rsegrest View Post
jsprigg,
Robyn
Robyn,
I think Doc Wu is on to something here. If he is correct, it looks like the example code from last year is the same for this year. Some fundamental changes have occured between the two seasons. I would suggest ignoring the example code (at least for the joystick)... and try to build your own example from the Basic Robot Code provided (when you build a new robot project) - the exact name/process escapes me right now.
Cheers,
- Jeff
Fresh Pancreas!
Unread 27-01-2010, 10:34
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
I just ran the LabVIEW Joystick Input Example - it worked for me. I have the Driver Station running, and I can read the joystick in Teleop Enabled or Teleop Disabled. A couple things to check:
1. On the DS Setup tab, do you see your joystick in the Joystick Setup list?
2. If you click the main button on your joystick, does the text in the Joystick Setup turn blue?
3. On the DS Diagnostics tab, are you getting any errors?
Unread 27-01-2010, 11:34
jsprigg's Avatar
Mad Scientist
AKA: Jeff Sprigg
Red face Re: Labview Joystick Input Example code not working
Now I feel stupid.
I just realized what we were doing wrong. The DS must be running when we run our code (DUH). We never had it running during testing. Guess I need to read the instructions more closely rather than 'skim' to the highlights.
See last year we would take for granted that the DS (blue box) handled the joysticks etc... for us. The new DS (laptop) can't handle I/O unless the DS software is running - which makes perfect sense.
Thanks for putting me on the right track. We'll give it a whirl tonight.
Cheers!
- Jeff
Fresh Pancreas!
Unread 27-01-2010, 19:50
rsegrest's Avatar
Jeff and Doug,
I am going to post this both here and in my thread in hopes of a quick answer. We tried steps and here are the results:
When we run the code and switch to the driver account:
1. Text turns blue when joystick buttons depressed
2. Robot code (right below the team number) turns solid green
However...still blinking yellow lights on jags...
Any ideas?
Thanks,
Robyn
~ Unknown
Unread 27-01-2010, 20:30
rsegrest's Avatar
WE HAVE MOTOR RESPONSE!!!!! Our programmer was reading your posts and banging his head against the classmate and motors and I walked to the back room to check on the mechanical when suddenly I heard motors spinning. The programmer said that there were LOTS of things wrong but had to go to tennis lesson before he could explain. He's coming back at 9:00 (CST) so will ask him what it was and post back then.
THANK YOU ALL FOR ALL YOUR HELP AND SUGGESTIONS!!!
What would we do without Delphi?!
~ Unknown
Unread 28-01-2010, 10:37
jsprigg's Avatar
Mad Scientist
AKA: Jeff Sprigg
Jeff and Doug,
Any ideas?
Thanks,
Robyn
Robyn,
Glad to hear you've got it working!
Our problem is solved... we weren't running the Driver Station program during testing :-)
Cheers,
- Jeff
Fresh Pancreas!
Unread 28-01-2010, 16:53
jhersh jhersh is offline
AKA: Joe Hershberger
FRC #2468 (Appreciate)
When we run the code and switch to the driver account...
In general, this is a bad way to do development. If you want to develop code on the classmate, you should simply run the driver station application from the start menu in the developer account, not switch accounts. If you switch accounts, you can get into a state where it's not clear to other people on your team what's running and you will end up wasting time trying to figure out why there is no communication with the robot. If you avoid doing this you won't risk this wild goose chase.
C++ Sample Code not working... hm29168 CAN 5 27-01-2010 20:59
Labview programming help - Deploy mode not working ferc Programming 3 20-10-2009 18:32
Activation of LabView still not working apollorest National Instruments LabVIEW and Data Acquisition 4 22-11-2008 21:09
Camera code not working.... DemonYawgmoth Programming 5 11-02-2006 09:21
frc_camera not working but labview does Issues Programming 7 18-01-2006 19:23
