Go to Post Machinery tends to make chips fly into weird places. Lathes and mills are particularly good at this, though drill presses are skilled as well. - Karibou [more]
Thread Tools Rating: Thread Rating: 32 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 27-01-2010, 10:36
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Re: 842 Final Kicker Design
Are you pressurizing the cylinder prior to releasing the latch ("pre-loading")?
Are you using the same valve for both sides of the cylinder?
Would you be willing to share with us what part number SMC you are using?
Thanks.
We are pre-loading the piston. We use the gate latch as a quick release.
Its the same SMC for both ends.
They are the SMC that came in the KOP last year.
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
  #32   Spotlight this post!
Unread 27-01-2010, 10:45
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
Thanks.
We are using this body - SY3000-27-1T
and this valve - SY3240-6H-S
You can find them on this - http://www.usfirst.org/uploadedFiles...klist-RevB.pdf
just Ctrl+F, it was from 2 years ago.
Team 842 Programmer
Pictures at:
Videos -
  #33   Spotlight this post!
Unread 27-01-2010, 10:58
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The trick is finding out where to purchase the part from. This is where we're stuck right now and may have to use 2009's SMC's until we figure it out. Anyone have any ideas?
GitHub
  #34   Spotlight this post!
Unread 27-01-2010, 11:07
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
Re: 842 Final Kicker Desgin
awesome and simplistic
mike d
See Ya
  #35   Spotlight this post!
Unread 27-01-2010, 13:41
Originally Posted by Mark Holschuh View Post
John,
Are you doing anything special to get the air out of the front of the cylinder faster when you kick the ball. A pressure relief valve?
If they did add a pressure relief valve, it would have to be set so high that it wouldn't do much good, no? They are driving this cylinder in both directions. The relief valve would have to remain closed while they are pressurizing the "front" side of the cylinder to retract the shaft against the bungee cord load.
#1860 kicker prototype sloteera General Forum 12 04-02-2010 14:27
987 Kicker Destruction JM987 General Forum 29 23-01-2010 16:46
FRC114 Kicker Teaser James114 Robot Showcase 10 22-01-2010 16:56
Hybrid Kicker falconmaster General Forum 15 20-01-2010 14:27
pic: The final...final match CD47-Bot Extra Discussion 4 17-04-2003 16:24
