Go to Post I like ice cream. - Andy Baker [more]
Unread 26-01-2010, 21:32
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Other legal compressors this year
Hello all,
We've been searching for alternate compressors that both match or beat the limits of the kit compressor, and are smaller/lighter. Has anyone had any luck finding any that fit within the rules this year, other than the kit compressor?
Any findings you all may have had would be useful, as I am sure many veterans would like to run with a smaller compressor this year.
Thanks,
Rob
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 26-01-2010, 22:41
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Other legal compressors this year
I was almost 100% sure any other compressor was illegal, but I stand corrected by <R75>. This is an intriguing idea, but I suspect it will be difficult to find a compressor thats much lighter than the one provided.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 26-01-2010, 23:05
monty1540's Avatar
monty1540 monty1540 is offline
College Student Mentor
AKA: Eric
FRC #1540 (The Flaming Chickens)
monty1540 is an unknown quantity at this point
Send a message via Yahoo to monty1540
From my previous research for a project of mine, I suggest investigating Viair compressors.
http://www.viaircorp.com/OffRoad/compressors.html
As far as I can tell some of their smaller models should fit within the maximum specifications given in <R75>
At least for the higher models I looked at for my project, google found many places to buy these compressors, and I'd guess the lower spec'd ones shouldn't be too hard to find either, but I haven't looked.
-Eric
Current WPI Student and college mentor to 1540
1540:
2008 Portland Regional Winner
2008 Portland Regional Engineering Inspiration Award
2007 Pacific Northwest Regional Finalist
2007 Pacific Northwest Reigonal Chariman's Award
Unread 26-01-2010, 23:10
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Now step back forward again.
Mike, you might want to check that you are looking at the proper year's manual. That text appears to be from <R72> from 2009.
<R75> Compressed air for the pneumatic system on the ROBOT must be provided by one and only one compressor. This compressor may be either the Thomas Industries compressor from the KOP, or an equivalent compressor that does not exceed any of the KOP compressor performance specifications (specifically: 12v, 0.8cfm flow rate, 120psi continuous pressure, 120psi maximum pressure compressor). Note: if an alternative compressor is used, during inspection the team may be required to provide documentation to show compliance with the performance specifications. Compressed air shall not come from any other source. The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in the storage tanks prior to bringing the ROBOT onto the FIELD. Off-board compressors must be controlled and powered by the ROBOT.
Unread 26-01-2010, 23:23
Roboticsrob
Now this brings up a good question about the wording of <R75>. I wonder if at any operating pressure, the max flow needs to be less than 0.8cfm, since the flow rates are variable as the pressure inside the system increases.
Unread 26-01-2010, 23:24
Electrical Engineer
Rookie Year: 1995
Kevin, et al,
Mea Culpa... I was going back and forth earlier trying to figure out what had changed...
Forget I chimed in...
Mike
Mike Betts
As easy as 355/113...
Unread 26-01-2010, 23:25
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I am really liking this compressor from viair :
http://www.cheaptruckparts.com/produ...e745a968a60d18
What is the consensus on this? Do we think its legal?
Mentor 2415
Unread 26-01-2010, 23:30
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Unfortunately the CFM @ 0 PSI looks to be over the .8CFM specified in the manual, so I would have to say no.
A quick glance suggests all the VIAIR compressors may suffer from this "issue".
Unread 26-01-2010, 23:36
It needs to not exceed the following: 12v, 0.8cfm flow rate, 120psi continuous pressure, 120psi maximum pressure. Plus the cost, COTS, etc.
COTS: Obviously COTS from a VENDOR.
Voltage: 12V. Good.
Flow rate: 1.03cfm flow rate at 0 PSI (under a 13.8V supply) could be an issue. It's lower at higher PSIs, but still...
Continuous pressure: Not listed that I can see. Not-so-great.
Maximum pressure: 120 PSI. Good.
Cost: Under the limit.
I'd try to find a full spec sheet for that. If none is available, I'd ask the GDC directly: We found this compressor, and we are unsure if it complies with X part of <R75>. Could you give a yea or nay?
As listed, I'd have to say nay. GDC beats me, though...
Unread 27-01-2010, 00:48
monty1540's Avatar
AKA: Eric
You all appear to be correct, the Viair compressors are all spec'd above the Thomas compressor from the kit. The Thomas datasheet for the kit compressor shows .79 cfm @ 0psi
(Kit compressor p/n 405ADC38/12 data shown on page 4 of below link)
http://www.gd-thomas.com/workareasho....aspx?id=21654
-Eric
1540:
Unread 27-01-2010, 11:54
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Here is a smaller compressor from VIAIR:
Direct Comparison:
Kit compressor
12v,
0.79cfm flow rate,
COTS
cost: in the KOP
Weight: 4.3 lb
VIAIR 63C
12v
0.79cfm flow rate,
100psi continuous pressure,
105psi maximum pressure
COTS
cost: $35
Weight: 1.43 lb (Its a third the weight!)
If we ask the GDC, I'd ask about this one.
Go REX!!!
Unread 27-01-2010, 12:52
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Direct Comparison:
Kit compressor
12v,
0.79cfm flow rate,
COTS
cost: in the KOP
Weight: 4.3 lb
VIAIR 63C
12v
0.79cfm flow rate,
COTS
cost: $35
It appears that the one you listed wouldn't be able to provide enough pressure to trip the 120PSI switch, and it is also not rated for 120PSI.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 27-01-2010, 13:18
Racer26 Racer26 is offline
yes, but if you can't generate 120psi, you dont need to be rated that high.
Unread 27-01-2010, 13:49
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Neither is the KOP compressor. Its only rated for 100 PSI, max.
Former Mentor Team 1771
Former mentor Team 4509
Unread 27-01-2010, 14:43
AKA: Sean
So for 1/3 of the weight and what looks like pretty similar specs this Viair compressor seems to be quite a cost effective weight saving means for teams using the compressor.
Mentor 2415
Are the Black jag's legal this year? Zanfardino2892 Electrical 2 25-01-2010 22:53
What's easier? Last year or this year? archiver 2001 2 23-06-2002 23:33
Last year vs. this year Fisher Price Gear bmusser Technical Discussion 4 29-01-2002 13:24
Legal way to remove bottles? and other questions jrukes Off-Season Events 4 15-10-2001 22:35
