Go to Post Hey Don, if the [Woody Flowers] award doesn't impress the non-FIRST friends and family, just tell them you have your own "inter-web thread" - tell them you are like a Chuck Norris on the internet!!! - ebarker [more]
Unread 27-01-2010, 15:02
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Other legal compressors this year
Yeah, just be sure to buy a few extras as spares...notice the duty cycle
63C Compressor Kit VIAIR
Price: $35.00 Part Number: 00063
# 12-Volt
# Duty Cycle: 20% @ 100 PSI
# Max. Working Pressure: 105 PSI
# Amp Draw: 7 Amps
# Inline Check Valve
# Dimensions: 5.00€ L x 3.00€ W x 5.00€ H
# Net Weight: 1.43 lbs
Unread 27-01-2010, 19:31
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
I'm sorry, could you explain what duty cycle means? I know that it describes how long the compressor will last, but what exactly does the 20% @ 100 PSI mean?
Go REX!!!
Unread 27-01-2010, 19:57
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Duty cycle means the percent of time that the unit may be operated. Ifyou have 20% duty cycle, it means that in any given 10 minute period, the motor may run a total of 2 minutes. Or, out of any given hour, it may run 12 minutes. It has to do with cooling.
I wouldn't recommend running it for 12 minutes and then off for 48, it would probably overheat.
The main point is that the motor should be off about 80% of the time.
Former Mentor Team 1771
Former mentor Team 4509
Unread 27-01-2010, 22:57
MrForbes's Avatar
AKA: Jim
Also the duty cycle rating is a rough indicator of how well the thing is made. Usually machines that are designed for long life in industrial use have a high duty cycle rating at full power, while cheap stuff has a very low duty cycle at full power.
You don't always get what you pay for, but you hardly ever get what you don't pay for.
Unread 28-01-2010, 01:43
Homsar66 Homsar66 is offline
AKA: Ryan
FRC #0122 (NASA Knights)
Team Role: Human Player
Homsar66 will become famous soon enough
That little compressor even has a better fill curve than the thomson, It's superior at higher PSI. If only you could run two of them, then you'd be golden.
Anyway, we've got a very old compressor I was playing around with. It's about the same weight as the KOP comressor, but doesn't overheat nearly as quickly and seems to fill faster as well. Its a Gast 22d model, someone might want to check it out but i can only find 22D models with 25 PSI max on their website and that sure isn't the one I'm looking for.
Unread 28-01-2010, 07:07
FRC #1727 (REX)
If it fills faster, then it is probably illegal unfortunately...
Go REX!!!
Unread 28-01-2010, 09:55
Racer26 Racer26 is offline
Has anyone asked Q&A about this particular compressor? I would, but I'm not my team's Q&A contact.
Unread 28-01-2010, 11:41
AKA: Ryan
Yes, but it all depends on the fill curve. It might fill at the same rate at zero psi(.79), but fill better at higher pressures. KOP fills only around .20 at 100 PSI
Unread 28-01-2010, 12:33
MrForbes's Avatar
AKA: Jim
That's how single stage piston compressors work, not much you can do about the laws of physics. Wonder if you could find a little, light, two stage?
Unread 01-02-2010, 13:31
Any news on this? I saw a Q&A with a non-committal answer from the GDC, with a link that I can't seem to read. Anybody know anything I don't? Saving a few pounds with a lighter compressor will lighten the weight pinch significantly.
Unread 03-02-2010, 05:45
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
http://forums.usfirst.org/showthread.php?t=14337
I guess the answer is to make a strong enough argument....you have 2 pages worth so far anyone want to sum it all in one strong statement?
Unread 12-02-2010, 13:26
Anybody planning to have a VIAIR 63C on their robot at competition?
Unread 12-02-2010, 13:30
BSEE, MSEE, JD
AKA: employed
According to a woman I spoke with at viair those have not been made for several years and are not available despite what internet resellers are claiming. She said most of them are drop ship resellers that are not aware they have been discontinued.
Unread 12-02-2010, 13:35
Ah... well then. Any alternatives?
Unread 15-02-2010, 10:45
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Any updates on a lighter, legal replacement. I haven't had any luck finding anything.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Are the Black jag's legal this year? Zanfardino2892 Electrical 2 25-01-2010 22:53
What's easier? Last year or this year? archiver 2001 2 23-06-2002 23:33
Last year vs. this year Fisher Price Gear bmusser Technical Discussion 4 29-01-2002 13:24
Legal way to remove bottles? and other questions jrukes Off-Season Events 4 15-10-2001 22:35
