Go to Post Dee and I pooling our brain cells almost make a full deck... - RoboMom [more]
Unread 27-01-2010, 15:28
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Testing Help
Is there some way that i can just have labview open on another laptop computer and just click the run command to test the code and edit on the fly. As opposed to logging on developer, build the code, run as startup, open driver station then it doesn't work, change the code, build the code, test and repeat.
Unread 27-01-2010, 16:01
Re: Testing Help
Yes.
Your other laptop just needs a compatible IP address and to be connected along with the Classmate through a router to the cRIO, that's all.
You can also just run the Driver Station app in the Developer account to avoid switching back and forth and to enable you to use the "Run" button.
Unread 27-01-2010, 22:56
FRC #0379
Re: Testing Help
So your saying take the other laptop ethernet port into the (blue or yellow port) of the blue router. then from the blue router (blue or yellow port) to the classmate. then i can run it on the non-classmate? (robot turned on obviously)
Unread 27-01-2010, 23:09
Re: Testing Help
Not the yellow port.
Any blue port will work.
Help with Testing Joystick jo3_sum NI LabVIEW 3 17-01-2010 21:18
Axis Camera Testing help koo_04 Programming 7 20-12-2008 13:55
Help testing RoboEmu 1.10 rbayer Programming 26 27-01-2003 06:50
Testing Jack Website Design/Showcase 0 27-12-2002 22:14
testing team222badbrad Chit-Chat 5 15-01-2002 09:49
