Go to Post Yes, machining a dog profile into a steel sprocket on a manual mill was an experience filled with pain and regret. - Joe G. [more]
Unread 27-01-2010, 15:31
wolfin1a5c's Avatar
wolfin1a5c wolfin1a5c is offline
FRC #2925
wolfin1a5c is an unknown quantity at this point
different ways to debug?
hia guys i was wondering if there was a way of debugging the lab-view FRC crio code without deploying the program. i ask because i want to work on the robot code at home and i cant take the crio with me. is there a program that could emulate the thing or am i asking a stupid question. any tip would help if not then i don't know...
team number:2925
team name: wv tech center
position: programmer
Unread 27-01-2010, 16:04
Re: different ways to debug?
No real easy way to emulate the cRIO at home.
The robot palette is dependent on the cRIO environment.
Unread 27-01-2010, 16:16
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
If it is just logic you are testing, you could always copy the vi over to the Computer side of things (it's right above the Real Time Target tree in the navigation panel like thing) and remove all the robot things. Kind of a pain to do, but depends on how determined you are.
-Tanner
Debug Windriver issue..... programmr C/C++ 12 06-02-2011 13:47
DIfferent Year CIMS run at materially different speeds ? de_ Motors 5 19-02-2009 13:04
Sidecar Debug NinjaSpawn94 NI LabVIEW 6 07-02-2009 10:48
Different ways to take tools to Atlanta deshirider430 General Forum 17 27-03-2008 11:43
Debug function in programming? archiver 2001 4 24-06-2002 00:34
