Re: pre-charged Pneumatics
Which leads to a question for Al... If a team had such a safety lock that was removed from their robot after placing it on the field, could they use it during the sizing part of inspection, but remove it when weighing the robot? If the safety lock is a few pounds for something real sturdy, it could make a real difference when being weighed. |
Ahh, but not all mechanisms are "charged" with air pressure. Teams that utilize springs or surgical tubing with a motor to charge their kicker may, depending on design, leave the kicker in a charged position when the robot is off, while having no pneumatics at all! And other teams will pressurize their robot from the cart in order to save weight (not have a compressor on their robot) - in such a case, you would have to carry it onto the field charged.
FIRST provided some good safety guidelines for precharged devices (and this forum came up with some more) a couple years ago for the trackball launchers.
Mind you... if your ball kicker has as much energy stored up as a trackball launcher, you ought to be able to kick balls up into the stands. My estimate so far is that we are using about 1/4 the force and about 1/2 the stroke on our pneumatic kicker that we did on our pneumatic launcher. Jason |
The answer would be yes and no. A safety lock could be used but under the rules for start orientation, the robot (not humans) has to be able to remove the lock after the match starts. The robot must be able to hold itself in the same size it did when in the sizing box at the start of the match. During previous games where mechanisms used considerable stored energy, the team had to demonstrate during inspection, that the stored energy could be released (safely and easily) prior to moving the robot on or off the field. One of the most impressive devices I have seen was on the Baxter robot during Overdrive. It used surgical tubing and a cam type charging device. To move the robot, a team member just needed to back the cam to the point where the tubing was no longer stretched. Those that played against Team 16 that year knows the effectiveness of that ball launcher. |
#7
Al,
I have to disagree with you (at least partially) on this one. If the safety lock, when removed, will cause deployment of a mechanism, I agree. If we are talking about making a trigger mechanism for a stored energy device absolutely foolproof safe but it's removal does not cause deployment, I not only think it legal but almost mandatory. We do not want accidental deployment of a mechanism when putting a robot onto or off of the field. Let's use a theoretical kicker for an example. It has a deflected spring and/or pre-charged pneumatic piston and a trigger that makes it fire. A pin in the trigger, removed after the robot is placed on the field, will prevent accidental firing while the robot is handled. The pin is never part of the robot during a match. It is in a team member's pocket. I would call this legal and almost mandatory. JMHO, Mike Last edited by Mike Betts : 28-01-2010 at 08:32. |
#8
Mike,
I would agree on this example provided the robot was able to fit in the box and start the match without said locking device in place. |
#9
Aircraft usually have a collection of locking pins with attached flags saying "remove before flight". They extend into visibility so that the ground crew can prepare the plane for use.
#10
(Not that we have ever forgotten to turn the breaker on........more than twice a day during competition. )Mind you, anyone that has done this little boo-boo is immediately demoted to "Freshman" for the day, regardless of how long they have been on the team, in school, or beyond. This even extends to our Mentors..... of which I am one,... and have worn this label. ![]() |
#11
yeah, I've even seen them on robots!
| I was charged to ship robot home from Atlanta | Sunshine | General Forum | 15 | 29-04-2008 16:14 |
| Beginning of Match - Charged tank | jdejoannis | Pneumatics | 6 | 30-01-2007 21:20 |
| Using pre-charged accumulators | Peter Matteson | Pneumatics | 8 | 14-02-2006 10:42 |
| 2006 Pre-Kickoff FF? | Billfred | Fantasy FIRST | 37 | 29-07-2005 11:11 |
| Charged 7.2 battery | Daniel Brim | Electrical | 2 | 01-02-2004 10:46 |
