Go to Post sigh, I started wondering why we weren't there than I realized it was in California. Thats a bit of a road trip... - Raumiester2010 [more]
Unread 27-01-2010, 16:04
camper365 camper365 is offline
FRC #1599
camper365 is an unknown quantity at this point
How to properly connect and program servo
We are having problems getting the servo to work. I have tried to find a schematic as to how to connect the servo properly (both power and data) but have had no luck. We might also be having code problems (I don't know for sure) so a method as to how to program the servo would be nice too.
Which call should I use to get and set the angle the servo is at? I think we are using set position now.
The world only has as much power over you as you let it have.
Linux: Here's the computer, just do stuff.
Unread 27-01-2010, 16:08
Re: How to properly connect and program servo
Servos connect to a PWM on the Digital Sidecar.
Each PWM MUST have a jumper installed next to it that provides power to the servo (otherwise it will never move).
That's how both power and data are handled.
Unread 27-01-2010, 16:15
FRC #1599
Is the jumper and the pwm cable two separate cables or just 1 special cable?
Unread 27-01-2010, 16:21
Use a regular PWM cable, the one that comes as part of the servo.
The jumper is a tiny little piece about 1/8" long and white or black that come in one of the electronics small parts bags. It just connects the two pins just to the side of the PWM connection on the Digital Sidecar.
The Program Compiles and Deploys, but the sidecar doesn't connect pj174208 Programming 1 14-02-2009 18:26
How to Program a Servo ExarKun666 C/C++ 5 06-02-2009 21:05
How to conect solenoids to the circuit board. and how to program it...??? arpitshah Pneumatics 6 13-01-2008 15:06
How to set up and run a FF League properly. Alex Cormier Fantasy FIRST 4 27-02-2006 17:18
