Go to Post Don't underestimate the ability of a highly skilled technician with simple tools (and don't overestimate the ability of an unskilled fool with exotic tools!). - dlavery [more]
Unread 27-01-2010, 16:49
qpang qpang is offline
qpang is an unknown quantity at this point
Driver Station?
I got confused on the Driver Station:
Are we going to use the Classmate Laptop as the driver station this year?
Or still the blue block, the one we used last year?
Or we can choose between them?
Which one should we plug the joysticks into?
Please enlighten me.
Unread 27-01-2010, 16:57
Re: Driver Station?
You must use this year's Classmate netbook as your Driver Station.
Plug the joysticks into the USB Hub and that into the Classmate.
Last year's blue box is not legal (but can be used at home if you want).
Unread 27-01-2010, 16:59
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Driver Station?
The Classmate PC will be used as the Driver's Station this year.
The "blue block" that served as the Driver's Station last year is not legal for use this year and should not be included as part of your system.
The joysticks should be plugged into a USB hub attached to the Classmate PC.
I'd highly recommend you read through the Control System Manual Chapter's 1 and 2 found here to assist you in setting up this year's control system. These documents will cover how to setup and test your control system for use this year.
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver station... the man Control System 16 06-01-2010 21:06
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
driver station corps FRC Control System 5 06-08-2009 20:44
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
