Go to Post I would like to meet...Andy Baker: I've never met a pig farmer before... - MissInformation [more]
Unread 27-01-2010, 17:18
JDM JDM is offline
programming lead; team executive;..
FRC #2199 (Robo-Lions)
JDM is on a distinguished road
Encoder Codewheel Won't Mount on Shaft
Hello,
We are having trouble getting one of our encoders installed onto a Toughbox. Normally, the codewheel of the encoder installs on to the shaft well and sort of "clicks" on, however with one of our Toughboxes the codewheel slides on and doesn't stay secure at all. We have tried different wheels that work fine on our other Toughboxes so we are pretty sure it is some kind of problem with the shaft. Does anyone have any idea what this might be, and if we have to get a new shaft from AndyMark, what part it is?
Thanks
Unread 27-01-2010, 17:26
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Encoder Codewheel Won't Mount on Shaft
The shaft may have ended up smaller than it is supposed to be preventing the codewheel from being a good tight fit.
The shaft is the output shaft am-0153.
Unread 27-01-2010, 17:29
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
Here http://www.youtube.com/watch?v=4hJfzhxZwKw
watch it at 2:08 it tells you how to fix it.
Unread 27-01-2010, 18:02
JDM JDM is offline
Thanks. We did what the video suggested with pliers and it seems to work great, but we also put some glue on just to make sure.
Screwing Encoder into Encoder Mount? Adrien Electrical 3 25-01-2009 18:14
How to mount rotary encoder Logan Williams Electrical 13 12-01-2009 20:00
pic: Rotary Encoder Mount Madison Extra Discussion 8 10-03-2008 21:44
Need Help with Encoder - Won't Count Clicks Kingofl337 Programming 5 16-02-2005 18:30
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
