Go to Post If you want to know how to build a more competitive robot, ask. GP demands we tell you, help you, guide you, teach you. - Al Skierkiewicz [more]
Unread 27-01-2010, 17:45
eaglesfan10's Avatar
eaglesfan10 eaglesfan10 is offline
FRC #1647 (Iron Devils)
eaglesfan10 is an unknown quantity at this point
No Robot Code
I'm having a problem getting code on the robot. We're able to undeploy and download the code using wind river, but when we reboot it shows a red light next to robot code. I'm not sure why it's doing it, I'm able to connect to and ping the robot controller.
For some reason, this works on one of the laptops, but not others. Any one have any ideas?
Unread 27-01-2010, 18:15
kennypu kennypu is offline
FRC #2467
kennypu is an unknown quantity at this point
Re: No Robot Code
this is the exact same problem I'm having right now. Windriver seems to download to cRIO fine, but the 'robot code' light stays red.
Unread 28-01-2010, 10:30
jalburty jalburty is offline
Joe Alburty
AKA: Joe Alburty
FRC #1763 (Paseo Pirates)
jalburty will become famous soon enoughjalburty will become famous soon enough
Send a message via ICQ to jalburty
Re: No Robot Code
Did you see this thread?
http://www.chiefdelphi.com/forums/sh...ad.php?t=80194
Unread 01-02-2010, 18:24
FRC #2467
Re: No Robot Code
The Driver Station is updated, I did the labview updates, but It still reports that there is no robot code.
EDIT:
I tried the 'run code at start up' thing that was in a doc file in the link jalburty gave, and I got it to work. Is there a similar thing for c++ though? because thats only labview. Is there a way to 'run code at start up' using windriver? Also, for some reason the voltage does not show, so I need to fix that as well. Thanks
Unread 01-02-2010, 21:17
Joe Alburty
AKA: Joe Alburty
Re: No Robot Code
I would confirm that you have the LabView default code running correctly by completely going through Chapter 2 of the 2010 FRC Control System Manual before moving on to C++. Do the joysticks work in both tethered and wireless configurations?
Here is where to find the manual:
http://www.usfirst.org/roboticsprogr....aspx?id=10934
Please keep us posted as to your progress.
Unread 01-02-2010, 23:34
FRC #2467
Re: No Robot Code
OK, I got it working, but in a different way. For somereason, the FIRST downloader in Windriver shows that it is uploading code to the cRIO, and gives no error, I looked into the cRIO through ftp, and saw that it had no code (it did not have the 'system/startup/...' directory). So All I did was created the folders and put the binary file in there manually and it worked. Anybody have a thought why the downloader was not working, or was I doing something wrong?
Unread 03-02-2010, 22:34
cmh0114 cmh0114 is offline
AKA: Cam H
FRC #0217 (Thunderchickens)
cmh0114 will become famous soon enoughcmh0114 will become famous soon enough
Re: No Robot Code
We had the same problem earlier today, and our solution was this: create a new project in WindRiver, and copy your old project over one file at a time. After each file, rebuild the project and redeploy it to the robot. When you find out exactly which file is giving you the problem while running, debug it and figure out exactly what's wrong with the file. It might not be the specific solution to your problem, but it might help you figure out your solution, or at least rule out a few things. Good luck!
Compressor Code causes No Robot Code Error sircedric4 C/C++ 25 03-02-2010 10:13
No Robot Code mlim NI LabVIEW 10 21-01-2010 17:33
Robot Code? leftylink Programming 0 18-02-2008 14:34
Compiling Robot code... greatman05 Programming 5 11-02-2008 21:50
Robot Timing Code robotrobot2 Programming 8 19-01-2008 14:18
