Go to Post Learning by failure is quite common. - Gdeaver [more]
Unread 27-01-2010, 18:01
Darth Pbal's Avatar
Darth Pbal Darth Pbal is offline
AKA: Paul Ronquillo
FRC #2375 (Biohazards)
Darth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud of
Re: Kicker Help?
Our robot and some other teams are using a combination of bungee chords and pneumatic pistons. If you use that and try your best to kick the ball at about 45 degrees you'd be able to clear about twenty feet uniformly. I've also heard of taking the pneumatic pistons and limiting how far the piston can pull back and that actually gives more room for pressure storage, giving the piston some more bang for you buck.
Does that help?
-Go Team 2375!
Darth Pbal
456 Kicker Video ChuckDickerson Robot Showcase 7 27-01-2010 00:58
Kicker Space Constraints Spirator Technical Discussion 3 24-01-2010 11:38
987 Kicker Destruction JM987 General Forum 29 23-01-2010 16:46
FRC114 Kicker Teaser James114 Robot Showcase 10 22-01-2010 16:56
Hybrid Kicker falconmaster General Forum 15 20-01-2010 14:27
