Re: Programming Mecanum
Ah, yes it works pretty well, except there's you gotta use
drive.holonomicDrive(leftStick.getMagnitude(), leftStick.getDirectionDegrees(), rightStick.getX()); One thing though: There's these weird delays, which I'm attempting to fix. |
Okay at this moment our programmers are working on trying to figure out the holonomic drive method. The motors are connected to the correct PWMs and we've been using the exact code given here in the forum but through our misfortune we have came up with the notion that the holonomic drive class has errors. Depending on what we do to our code the wheels will run in opposite directions, forward, or rotate; but never reverse.
We think it has something to do with the order of the parameters. Our programming works better if we put rotation where magnitude goes and vice versa. Direction is still much of a mystery. As you can probably surmise from this entry our troupe of programmers are confused at this point. Right now our mentor is planning to copy the holonomic drive class in order to play with it to see if that yields any positive results. |
Do you need to set the motors on one side inverted? When we first just tried we noticed the wheels on one side were reversed and we needed to add:
setInvertedMotor(RobotDrive.MotorType motor, boolean isInverted) |
Can someone please post the java scource code for the holonomicDrive Function?
public void holonomicDrive(double magnitude, double direction, double rotation) {
double frontLeftSpeed, rearLeftSpeed, frontRightSpeed, rearRightSpeed;
magnitude = limit(magnitude);
double cosD = Math.cos((direction + 45.0) * 3.14159 / 180.0);
double sinD = Math.cos((direction - 45.0) * 3.14159 / 180.0);
frontLeftSpeed = limit((sinD * magnitude + rotation));
rearLeftSpeed = limit((cosD * magnitude + rotation));
frontRightSpeed = limit((cosD * magnitude - rotation));
rearRightSpeed = limit((sinD * magnitude - rotation));
m_frontLeftMotor.set(frontLeftSpeed * m_invertedMotors[MotorType.kFrontLeft_val]);
m_frontRightMotor.set(frontRightSpeed * m_invertedMotors[MotorType.kFrontRight_val]);
m_rearLeftMotor.set(rearLeftSpeed * m_invertedMotors[MotorType.kRearLeft_val]);
m_rearRightMotor.set(rearRightSpeed * m_invertedMotors[MotorType.kRearRight_val]);
| Mecanum Programming Help | Mars | Programming | 8 | 27-02-2008 15:41 |
| Bizarre Mecanum Programming Bug | manderson5192 | Programming | 10 | 08-02-2008 22:11 |
| Mecanum drivetrain programming problems | Mr. Freeman | Programming | 4 | 21-03-2007 17:11 |
| mecanum programming | mrmummert | Programming | 27 | 28-01-2007 13:45 |
| programming motors with programming kit | BorisTheBlade | FIRST Tech Challenge | 4 | 01-11-2005 19:03 |
