Go to Post It doesn't matter if students get inspiration from planning to creating to manufacturing to purchasing to watching to engineers creating the parts etc etc etc. As long as students are getting Inspired, FIRST is doing it's mission. - David Kelly [more]
Unread 23-01-2010, 13:29
xionphoenix xionphoenix is offline
FRC #2342
xionphoenix is an unknown quantity at this point
Error in Simple Template
I was recently trying to get throttle code working for our robot and I was using the simple template, even without making any changes to the code It comes up with a build error without any location
the error reads
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: *** [SimpleTemplate_partialImage/Debug/Objects/SimpleTemplate/MyRobot.o] Error 127
Build Failed in Project 'SimpleTemplate' (Process Exit Value was 2): 2010-01-23 13:28:58 (Elapsed Time: 00:00)
Location Unknown
*note, the error comes up no matter what changes i do or do not make
please help
thx
Unread 23-01-2010, 13:36
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Error in Simple Template
A wild guess here.
Try closing and then reopening the project in Workbench.
After reopening, make sure you rebuild (not build) the project.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 23-01-2010, 13:41
FRC #2342
when i try to hit re-build, the selection is grayed out as well as all the other choices in that sub menu
Unread 23-01-2010, 13:45
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
Seems as though your project is hosed -- or maybe your whole installation.
Have you been able to build any projects?
If so, can you create the project again (give it a different name)?
Unread 27-01-2010, 15:18
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Nope, that means you have automatically build selected.
Watchdog.Kill();
Unread 27-01-2010, 16:38
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
I had to ponder this a while just to get to the point where I think I understand what you're saying.
You're saying there's an option somewhere which if selected means you can't build or rebuild a project other than automatically?
If that's correct, where is this option and what does one do to cause an automatic build of the project?
I know Workbench fairly well, don't claim to know everything about it though, and I'd like to understand your reply.
Unread 27-01-2010, 18:48
byteit101's Avatar
When you save it builds.
look on page 9 of http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
but disable it instead
Watchdog.Kill();
Unread 27-01-2010, 19:21
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
I have to admit, I never knew that preference existed.
I can see where it might be useful to some folks.
In practice, I think one rarely wants the project to be built every time one saves a file -- unless it's a one source file project.
Nonetheless, useful feature or not, enabling it does not render me unable to rebuild projects by right-clicking the project and selecting rebuild-- I just tried it.
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
Template Project Astronouth7303 Programming 10 30-05-2004 20:05
Simple Syntax Error miketwalker Programming 6 06-01-2004 00:17
