Go to Post Once you go hex you'll never go back. - sdcantrell56 [more]
View Poll Results: What type of wheels are you using on your robot?
8-inch Mecanum Wheels 15 42.86%
10-inch+ Mecanum Wheels 1 2.86%
I'm not even using Mecanum 19 54.29%
Voters: 35. You may not vote on this poll
Unread 27-01-2010, 19:08
Syphorce's Avatar
Syphorce Syphorce is offline
FRC #2344 (2344)
Team Role: Electrical
Syphorce is an unknown quantity at this point
Send a message via AIM to Syphorce Send a message via MSN to Syphorce
8inch Mecs or 10 inch?
I wanted hear your opinion on which set of wheels are better, the 8-inch Mecanums or the 10 inch Mecanums. You would think that they would be the same thing but actually the rolles are different. The 8-inch seem to have more friction than on the 10-inch Mecanums. Post your opinions here.
Unread 27-01-2010, 19:55
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: 8inch Mecs or 10 inch?
If you are referring to the AndyMark mecanum wheels, you may want to take a look at the weight of the 10" wheels.
7 lbs per wheel for aluminum = 28 lbs in wheels alone!
14 lbs per wheel for steel = 54 lbs in wheels alone!
When compared with the 8" model however:
2.5 lbs per wheel = 10 lbs in wheels
*This is less than 1 steel 10" or 2 aluminum 10" wheels.*
Price is also a HUGE factor:
$710 for a set of 10"
$310 for a set of 8"
Direct from the 8" page:
Tension on the roller can be adjusted by loosening or tightening the 12 Nylock rollers on the perimeter screws. Tighten the nylock nut for a more restricted roll. Loosen the nut for a more freely spinning roller.
The friction should be no problem what so ever as the wheels are completely adjustable. Many teams have had great success with the 8" version. I personally see no reason to go all the way up to the 10".
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
last i checked the 10" mechs were listed at 10lbs a piece. 40lb wheels? well i guess it would lower your CoG.
Unread 27-01-2010, 20:03
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
We considered 10 inchers for about 10 minutes until we saw the weight and cost
Of course.....there is that coolness factor, because those things just look amazing. I'd go with 8 inch though, much cheaper and lighter. And I don't see how the 10 inch could be THAT much more effective.
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 27-01-2010, 20:20
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
If you had truly ridiculous machining capabilities, you could convert bicycle wheels to mecanum. But for actually practical use, I would use the 8 inchers. They are better in most ways.
Go REX!!!
Unread 27-01-2010, 20:25
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Could you add an option for "I want mechanum wheels"? I want Mechanum wheels, but my team doesn't! Well, I wouldn't say doesn't they just have more important matters on their mind...
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 27-01-2010, 20:30
dtengineering's Avatar
AKA: Jason Brett
The 10" wheels look like they would run much more smoothly, but are not, I believe, FRC legal.
8.3.3.1 G states:
If the modules are designed to assemble into a single configuration, and the assembly is functional in only that configuration, then the total cost of the complete assembly including all modules must fit within the price constraints defined in Rule <R22>.
So at $710, they would exceed the $400 limit.
But they are really cool....
Jason
Unread 27-01-2010, 20:36
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
That was a short break
FRC #2826 (Wave Robotics)
We're using the 6in mecanums but you don't have them in your pole, when went based on price and the 6 in are getting us over the bump just fine.
2012-2016 Wave Robotics Team 2826
Unread 27-01-2010, 21:53
Gone Fishin'
8.3.3.1 G states:
Jason
However, you can buy each wheel for $180, which is allowed per COTS rule... this would have to be a Q&A question. It is possible to use 2 mecanum wheels to give a "car" like steering system.
Unread 27-01-2010, 22:11
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Were using 6"
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
3-inch rule Pneumaticsman Rules/Strategy 1 16-01-2010 16:55
3 inch penetration longrange Rules/Strategy 4 13-01-2010 19:03
4 inch wheels R.C. Technical Discussion 13 12-06-2008 17:58
80 inch diameter? Pneumaticsman Technical Discussion 4 15-01-2008 08:54
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
