Go to Post Don't rely on the field staff to get every ball to work with your machine....engineer a robot that makes the change not matter. - PayneTrain [more]
Unread 27-01-2010, 17:52
infocus infocus is offline
infocus is an unknown quantity at this point
Kicker Help?
We've designed a mechanism using the bungee cords that can produce 75lbs of force at the end of our kicker. But we fail to move the ball over one bump. Is 75 lbs enough force? Or is it possible that there is something fundamentally wrong with our kicker design. Any help will be greatly appreciated.
Unread 27-01-2010, 18:01
Darth Pbal's Avatar
Darth Pbal Darth Pbal is offline
AKA: Paul Ronquillo
FRC #2375 (Biohazards)
Darth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud of
Re: Kicker Help?
Our robot and some other teams are using a combination of bungee chords and pneumatic pistons. If you use that and try your best to kick the ball at about 45 degrees you'd be able to clear about twenty feet uniformly. I've also heard of taking the pneumatic pistons and limiting how far the piston can pull back and that actually gives more room for pressure storage, giving the piston some more bang for you buck.
Does that help?
-Go Team 2375!
Darth Pbal
Unread 27-01-2010, 19:14
Re: Kicker Help?
We've been prototyping the same concept, but for some reason can't get more then 10 feet out of a shot. Could you offer us any more insight or advice?
Unread 27-01-2010, 19:22
ttldomination's Avatar
Sunny
Re: Kicker Help?
75 pounds is A LOT. We'd have roughly 30-40 (50 pounds at our strongest) and we can get a decent 30-25 feet. It really also depends on how far away your point of rotation is sitting, generally farther is better.
If you don't mind, post a picture/video of your setup, and that'd be better for us to help out.
Also, are you manually releasing it or is there a mechanism involved? Depending on what you're doing, you could have a mechanism that's burning too much energy in the release.
Try messing with the angle of incidence and size of kicker and see what you get. I would recommend messing around with wood prototypes because they are much easier to change/modify than metal/80-20.
1648: 2013-2014
5283: 2015
Unread 27-01-2010, 19:32
Newo95's Avatar
Newo95 Newo95 is offline
AKA: Owen
FRC #0540 (Talon 540)
Newo95 is infamous around these partsNewo95 is infamous around these partsNewo95 is infamous around these parts
Re: Kicker Help?
We have come up with a design using surgical tubing included in the kit that is able to get the ball over the hump easily when a wedge is added to the end of the kicker. In one of our tests, we fired it after school down an empty hall way to see how far it would go, and it hit the ceiling almost knocking down a tile. It seams that noone has mensioned puting a wedge at the end of their kicker, and I think that is why you are not getting the lift to get over the hump. you have plenty of power, but you need lift to fly over the hump, or topspin to roll over it
Unread 27-01-2010, 20:01
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Kicker Help?
I would bet it has to do with where you are striking the ball.
We found the best sucess by striking the ball 2.5-3" off the ground.
Unread 27-01-2010, 20:13
Andrew.Jensen Andrew.Jensen is offline
FRC #2240 (Brute Force)
Team Role: Student
Andrew.Jensen is on a distinguished road
Re: Kicker Help?
Our team has designed several that work well with surgical tubing. I'm not sure the force we use, but it isn't much. We are, however, able to launch a ball quite some distance. You might be wasting lots of energy in your release. Also, the way that the kicker connects with the ball is important. We used a wedge to hit the ball causing it to go in more of a diagonal arc.
Unread 28-01-2010, 00:09
Darth Pbal's Avatar
AKA: Paul Ronquillo
Re: Kicker Help?
Well my team hasn't completed our kicker design yet. but here's a link to a team that we work with that has utterly beautiful performance on their kicker. Pause and study the vid a bit.
Video
if you can't access youtube because of blocks or whatever just click on my signature and you'll go to my teams blog. I've posted the video of that kicker up.
It's not my teams robot though. It's a high school that were working with closely.
-Go Team 2375!
Darth Pbal
Unread 28-01-2010, 00:22
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Re: Kicker Help?
How much Travel do you have, in what ever hit the ball?
What is the mass of whatever is hitting the ball?
What is your config?
A picture would really help...
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 28-01-2010, 16:09
Re: Kicker Help?
Could you guys please explain what you mean by a wedge? Just what kind of shape, what angle its at, etc.
Unread 28-01-2010, 17:03
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Kicker Help?
Some basic things to consider are:
1) Maximize impact velocity on the ball.
2) Make sure the kicker follows through on the kick.
3) The mass of the kicker is not as important as the velocity, but it helps.
Ke = (M/2)*(V*V)
Kinetic Energy = (mass/2) * velocity squared
Maximizing kicker velocity will also help compress the ball. The ball will return that energy in the form of velocity, and distance, if it is still in contact with the kicker when decompressing, thus the need for follow through. Having more mass will enhance this process as it will the kicker to not decelerate as much when the kicker impacts the ball.
Unread 28-01-2010, 17:16
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Kicker Help?
Second Bill's suggestions. Once you have enough mass that the kicker isn't stopping upon impact with the ball, velocity is the primary driver of kicking distance. He didn't mention it, but mass is inversely proportional to kicking speed. More mass = less speed = less kicking distance. I'd recommend lightening your kicker until you start seeing diminishing returns in kicking distance.
Unread 28-01-2010, 17:24
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Kicker Help?
The first thing I would look at changing would be what is hitting the ball. We are still optimizing this, but 30-50 degrees (from vertical) is the range we have determined to be the best so far for the angled plate we have attached to our leg. Also some people aren't thinking realistically about how hard or far you need to hit the ball. Remember your never going to be 18ft away from the bump because in the far zones there is only 17.5ft from wall to bump and 17ft in the middle, plus your robots dimensions will take up some of that space, so plan that the max, if your right up against the wall would be around 15 to 14ft, depending on your robot's dimensions. Also your not going to be right up against the wall so make sure you try seeing if you can just change the distance your firing from.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 28-01-2010, 17:25
jamie_1930's Avatar
Team Role: Student
Re: Kicker Help?
Ke = M*(V*V)
Kinetic Energy = mass * velocity squared
Kinetic Energy = (1/2)m(v*v)
2009
2008
Unread 28-01-2010, 17:30
billbo911's Avatar
Re: Kicker Help?
OOOoooops, you are absolutely correct. I have edited my post to reflect this.
Man, it has been a long while since I had that physics class.
Thank goodness physics doesn't change just because you forget the formula.
456 Kicker Video ChuckDickerson Robot Showcase 7 27-01-2010 00:58
Kicker Space Constraints Spirator Technical Discussion 3 24-01-2010 11:38
987 Kicker Destruction JM987 General Forum 29 23-01-2010 16:46
FRC114 Kicker Teaser James114 Robot Showcase 10 22-01-2010 16:56
Hybrid Kicker falconmaster General Forum 15 20-01-2010 14:27
