Go to Post Sloppy thinking leads to sloppy designs... - Joe Johnson [more]
Unread 27-01-2010, 21:03
hans4's Avatar
hans4 hans4 is offline
AKA: Nick H
FRC #2002
hans4 is an unknown quantity at this point
Electromagnetic gate latch?
Hey everyone, new to the forums, and i hope this is the right section, my team is looking into using an electromagnetic gate latch to hold back a tension powered ram. We were wondering if it would be legal as long as we powered it from the distribution board.
We were thinking something like this product: http://www.usbuilderstore.com/securi...gate-lock.html
not this exact model but the same idea.
What do you guys think?
thanks
Team 2002
Unread 27-01-2010, 21:19
Re: Electromagnetic gate latch?
The latch would be moving under the influence of the electromagnet, wouldn't it?
The Q&A has dealt with several questions on electromagnets.
http://forums.usfirst.org/showthread.php?t=13979
http://forums.usfirst.org/showthread.php?t=14121 Note that this one outlaws any use of electromagnets to provide motion.
http://forums.usfirst.org/showthread.php?t=14093
Due to the second response linked (there are more than 3 out there, trust me), if you're moving the ram with the electromagnet, you are in violation of the rules. By the looks of things, the latch is activated by the electromagnet, making it illegal per <R53> as interpreted by the Q&A.
Unread 27-01-2010, 21:46
hans4's Avatar
AKA: Nick H
FRC #2002
Thanks for the quick response EricH,
However i dont understand what is illegal about this system. All it does is sit there and close on the incoming object then we supply it power and then releases said object when we are ready to fire...
Clarification please?
Thanks
Unread 27-01-2010, 22:01
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
The electro magnet cannot move something because it is providing motion. But I think you can use it to hold something with electromagnetic force and then release it when you want by turning off the magnet. That is legal because we did it in 2008 to great effect.
Unread 27-01-2010, 22:18
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Thanks
If the electromagnet in the lock moves something to release the latch it is illegal as an electromagnet providing motion has been ruled by the GDC to be a solenoid per the responses Eric linked.
If the electromagnet just holds the part in place, then releases it, with no motion of latch parts then you should be OK.
Unread 28-01-2010, 11:34
hans4's Avatar
AKA: Nick H
FRC #2002
Thanks guys,
I think we will try the electromagnetic latch, but we'll build a backup system in case we get to regionals and FIRST says we cant.
Thanks Again,
Hans
Unread 28-01-2010, 12:00
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
This "electromagnetic latch" is a solenoid actuator, which is expressly prohibited. There is no doubt it will be disallowed at inspection, unless it is not noticed AND you don't reveal it. Not worth the risk. Use a small air cylinder.
Unread 28-01-2010, 13:13
It won't pass inspection, unless your inspector doesn't notice it. And with that packaging, I'm fairly certain they'll ask. A number of head inspectors also read CD on a regular basis--if yours is one of those, you're already not going to pass. Don't try to pass with it on your robot.
Unread 28-01-2010, 13:34
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
[quote=Vikesrock;908225If the electromagnet just holds the part in place, then releases it, with no motion of latch parts then you should be OK.[/QUOTE]
I'd like to see a GDC ruling on this !
Holding is different than actuating.
Ed Barker
Unread 28-01-2010, 13:39
The GDC has ruled on holding already--see that second Q&A I linked. The part in question certainly seems to be an actuated device.
Unread 28-01-2010, 13:40
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The GDC has been fairly clear.
Use a magnet to hold your claw to the bar? Fine.
Use a magnet to cause something to move? Not fine.
However, if someone still has a question, post it on the Q&A. None of our answers are official.
Unread 28-01-2010, 23:37
hans4's Avatar
AKA: Nick H
FRC #2002
haha thanks for the tip, i've been looking into just an electromagnet with no latch instead, but we'll probably go with a piston (more cost effective) ya you're right about inspection too
Thanks again
Unread 29-01-2010, 00:51
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
For less than 1/2 the price of the gate latch you were looking at you can get an electromagnet rated for 160 lbs from McMaster-Carr part #5698K312.
All you would have to do is put an iron plate at the end of your kicker and make sure that the plate is pressed firmly against the electromagnet before the magnet is engaged.
However it is important to remember that the iron may become magnetized with unexpected results!
Unread 09-02-2010, 00:37
NerdGuy's Avatar
NerdGuy NerdGuy is offline
FRC #2974
NerdGuy is an unknown quantity at this point
So do we have to buy the electromagnet or can we make our own.
I mean honestly, making an electromagnet is something i did in elementary school.
The only thing i am not sure about is does that violate the custom circuits rule?
Any help would be greatly appreciated.
"Life would be so much easier if we only had the source code."
Unread 09-02-2010, 01:40
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
So am I understanding this thread correctly, that if I have an aluminum pivot bar having a pin & a spring at one end, and a steel plate at other end, if my pin engages a bungee powered arm, locking it in place, and uses a spring around the pin that's pushing to disengage it, then if my electromagnet's grip on the steel plate on opposite end of aluminum pivot bar prevents spring from disengaging pin at other end of aluminum bar until the electromagnet is de-energized, allowing bar to now pivot from the spring's force, and disengaging the pin --- is this a violation?
The electromagnet merely releases its grip on a steel plate, allowing the previously overpowered weaker SPRING to now actuate the release of the pin. What element is the real actuator here ? Is it the electromagnet, or is it the spring?
Is it that an electromagnet MOVING an element is forbidden, but RELEASING ITS GRIP on an element is allowed?
-Dick Ledford
electromagnetic solenoid blnace97 Rules/Strategy 9 13-01-2010 10:48
pic: Delta field at River Rage - Load In/Out Gate closing the gate skimoose Extra Discussion 4 09-11-2009 11:55
2264 needs some help with a latch. vivek16 Technical Discussion 1 29-02-2008 01:52
pic: Carriage Latch Release Curt Henderson Extra Discussion 0 24-02-2008 17:09
Electromagnetic solenoids brandy836 Electrical 4 24-01-2006 08:26
