Go to Post Consider that the 12V from your robot isn't any different from the 12V from your car's cigarette lighter. (Err... sorry... that's "power port" these days, thank goodness.) - dtengineering [more]
Unread 27-01-2010, 22:11
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: HEy
Technically, you can block the balls.
But you will get penalized.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 27-01-2010, 22:12
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: HEy
under what rule alex?
Unread 27-01-2010, 22:13
FRC #1405
Re: HEy
On the rail system, of course.
Unread 27-01-2010, 23:03
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Re: HEy
There is a lot of misinformation in this thread right now.
In Autonomous mode it will be difficult to block balls or robots as you are not allowed to go fully across the centerline. Moving fully across the centerline will result in 2 penalties, plus 2 more penalties and a yellow card if a ball or robot is contacted while fully across the centerline, plus 2 more penalties for any additional balls or robots contacted. <G28>
In Teleoperated mode only one alliance robot may be in the Far zone (the zone near your opponent's goals) per rule <G29>.
There are restrictions regarding the use of active mechanisms above the bumpers (<G45>), so you may not use such a mechanism to block the ball.
There are no restrictions on blocking balls with your bumpers or any other passive mechanism on your robot.
In most cases, robots may be blocked or pushed as much as you wish. If you are pinning the robot (including having one robot block each side of the tunnel) you must back up 6ft. for 3 seconds after each 5 second pin <G39>. Robots in contact with their tower or an elevated alliance partner during the Finale period cannot be defended <G34>. Robots must be given a 10-second grace period from contact when righting themselves or others <G32>.
I believe I have covered most of the common scenarios regarding ball and robot blocking, but as always the manual itself (and the Q&A) is the only source of official information.
Unread 27-01-2010, 23:09
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: HEy
Originally Posted by Vikesrock View Post
Robots in contact with their tower or an elevated alliance partner cannot be defended <G34>.
This applies only to the finale otherwise there can be interaction to a suspended robot as per Q&A. Also any penalties caused by the suspended robot, even if caused by another robot will be charged against the suspended robot.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 27-01-2010, 23:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: HEy
Thanks Steve, I knew that, must have had a disconnect between my brain and fingers. I adjusted my original post to reflect this correction.
Blocking balls with balls allowed? MrBamboo Rules/Strategy 16 27-01-2006 19:59
pic: 121 was there. Where was the competition! CD47-Bot Extra Discussion 3 19-04-2004 15:48
Legality of Blocking Ball Chutes Aignam Rules/Strategy 29 12-01-2004 14:32
Hey, Hey, Ken Leung archiver 2001 0 24-06-2002 00:28
Hey, Hey Bill Gold Ken Loyd General Forum 2 08-11-2001 06:09
