Go to Post Checklist: Robot on, thinkamajig set, autonomous set, safety bar pulled. - DonRotolo [more]
Unread 27-01-2010, 21:50
Ahren Ahren is offline
FRC #1692
Ahren is an unknown quantity at this point
Legality of blocking balls (was: HEy)
can we block balls purposely? and or accdentaly?
can a ball hit our bumpers and we not get a peanalty???
Unread 27-01-2010, 21:55
fordchrist675's Avatar
fordchrist675 fordchrist675 is offline
"Wilfordito"
AKA: Wilford Jay Harris III
FRC #0675 (Technology High School Robotics)
fordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to all
Send a message via AIM to fordchrist675 Send a message via MSN to fordchrist675 Send a message via Yahoo to fordchrist675
Re: HEy
From what I read your not allowed to block either a ball or a robot on purpose. Especially around the tunnel area.
It's not by how much you win, it's how you win. Respect your enemies, otherwise your no better than them which if you think about it that's true because we are striving for the same thing. To be FIRST
2010 SVR Creativity Award
2010 SVR Regional Finalists
2010 SAC Innovation in Control Award
Unread 27-01-2010, 22:01
Andrew.Jensen Andrew.Jensen is offline
FRC #2240 (Brute Force)
Team Role: Student
Andrew.Jensen is on a distinguished road
Re: HEy
Friend, there's a magical thing called the manual. It will tell you the answers. You are able to have one robot on defense, which can deflect balls, but a robot whose sole purpose is aimed at offensive actions against the enemies will be yellow carded.
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: HEy
Yes you may block balls but can not use an active mechanisum above the bumper zone. read rules G43-47. None which say it is against the rules to play D by blocking a shot with your robot.
Unread 27-01-2010, 22:11
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: HEy
Technically, you can block the balls.
But you will get penalized.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 27-01-2010, 22:12
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Re: HEy
under what rule alex?
Unread 27-01-2010, 22:13
FRC #1405
Re: HEy
On the rail system, of course.
Unread 27-01-2010, 23:03
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: HEy
There is a lot of misinformation in this thread right now.
In Autonomous mode it will be difficult to block balls or robots as you are not allowed to go fully across the centerline. Moving fully across the centerline will result in 2 penalties, plus 2 more penalties and a yellow card if a ball or robot is contacted while fully across the centerline, plus 2 more penalties for any additional balls or robots contacted. <G28>
In Teleoperated mode only one alliance robot may be in the Far zone (the zone near your opponent's goals) per rule <G29>.
There are restrictions regarding the use of active mechanisms above the bumpers (<G45>), so you may not use such a mechanism to block the ball.
There are no restrictions on blocking balls with your bumpers or any other passive mechanism on your robot.
In most cases, robots may be blocked or pushed as much as you wish. If you are pinning the robot (including having one robot block each side of the tunnel) you must back up 6ft. for 3 seconds after each 5 second pin <G39>. Robots in contact with their tower or an elevated alliance partner during the Finale period cannot be defended <G34>. Robots must be given a 10-second grace period from contact when righting themselves or others <G32>.
I believe I have covered most of the common scenarios regarding ball and robot blocking, but as always the manual itself (and the Q&A) is the only source of official information.
Unread 27-01-2010, 23:09
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: HEy
Originally Posted by Vikesrock View Post
Robots in contact with their tower or an elevated alliance partner cannot be defended <G34>.
This applies only to the finale otherwise there can be interaction to a suspended robot as per Q&A. Also any penalties caused by the suspended robot, even if caused by another robot will be charged against the suspended robot.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 27-01-2010, 23:10
Billfred's Avatar
Billfred Billfred is offline
Re: Legality of blocking balls (was: HEy)
Adjusted the title to be more specific (and thus reader-friendly) and moving it to the rules forum (which, of course, is no substitute for reading the manual and FRC's official Q&A).
Unread 27-01-2010, 23:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: HEy
Thanks Steve, I knew that, must have had a disconnect between my brain and fingers. I adjusted my original post to reflect this correction.
Unread 28-01-2010, 01:13
One other one: Blocking balls in contact with the ball return is 2 penalties per ball under <G47>.
Blocking balls with balls allowed? MrBamboo Rules/Strategy 16 27-01-2006 19:59
pic: 121 was there. Where was the competition! CD47-Bot Extra Discussion 3 19-04-2004 15:48
Legality of Blocking Ball Chutes Aignam Rules/Strategy 29 12-01-2004 14:32
Hey, Hey, Ken Leung archiver 2001 0 24-06-2002 00:28
Hey, Hey Bill Gold Ken Loyd General Forum 2 08-11-2001 06:09
