Go to Post The kids will still be inspired, just keep FIRST competitive. - MikeDubreuil [more]
Unread 26-01-2010, 10:35
Jordan2389Diaz's Avatar
Jordan2389Diaz Jordan2389Diaz is offline
Grant me your power...Verto
FRC #2389 (Pirate Robotics)
Team Role: Tactician
Jordan2389Diaz can only hope to improve
Bungy and Surgical tubing
My team is trying to hook up our pneumatics system but we are wondering how power it would be? How do you hook up the surgical tubing and the bungy cords to the robot.
Lord is my Shepherd I shall not want-Psalms 23
Unread 26-01-2010, 10:38
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Bungy and Surgical tubing
Go to you tube and search 842 kicker and u will several great examples.
Unread 26-01-2010, 21:08
DonRotolo's Avatar
Back to humble
FRC #0832
Of course, the surgical latex tubing is not intended to be part of the pneumatic system.
The FRC Manual does explain a bit about how to connect the pneumatics. the FIRST Pneumatics Manual goes into greater detail. Both should be read before you do anything more.
As for the latex tubing, we have used it in the past as a spring to retract a mechanism, a cushion for a mechanism that hit the frame too hard, and in place of a rope or wire to kpps game pieces from falling out of the storage hopper.
This year, we tied some into a loop, and use it like a big rubber band to power the kicker. A pneumatic piston pulls the kicker back for another shot.
Unread 26-01-2010, 22:58
Team 2811's Avatar
Team 2811 Team 2811 is offline
WHAT DID YOU DO!? ..umm... whoops!
AKA: Ian Heffron
FRC #2811 (Stormbots)
Team Role: Electrical
Team 2811 is on a distinguished road
Yeah, I am with you on this one. The surgical tubing is not recommended or intended for the pneumatics system. It would not be a wise choice to do so, because depending on the amount of pressure that you need for your pneumatic system, the surgical tubing could expand and "pop" off of whatever you attach it to in the system.
Its about a day out!
Once, there were two marshmallows roasting over a campfire.
First marshmallow, "It is really hot up here."
Second marshmallow, "OH MY GOD ITS A TALKING MARSHMALLOW!!!"
The more you learn the more you know
The more you know the more you forget
The more you forget the less you know
So why learn?
Unread 27-01-2010, 22:14
DonRotolo's Avatar
Back to humble
FRC #0832
Not to mention it's prohibited by <R72>
Unread 01-02-2010, 10:11
Taxi Quinn's Avatar
Taxi Quinn Taxi Quinn is offline
FRC #2389
Taxi Quinn is infamous around these partsTaxi Quinn is infamous around these parts
I dont understand what you are saying is prohibited? We are currently looking in the manual in the section you said, and we can find notheing that says anything is prohibited.
The Big Taxi
Fight, No Flight
"Snarky. Yeah it's a word! Google that...."-Dane Cook
Unread 01-02-2010, 10:19
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Originally Posted by Taxi Quinn View Post
We are currently looking in the manual in the section you said, and we can find notheing that says its prohibited
You may want to re read it Quinn. R72 specifically states what you are allowed to use in your pneumatic system and surgical tubing is not on there as it would be very unsafe to use in a pneumatic system. So Don is 100% correct.
Unread 01-02-2010, 12:54
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
Does your piston move during the shot? Most video examples I've seen of various pneumatic/tubing kickers show the piston moving during the shot.
If your piston moves during the shot, does it move faster than 20 inches per second?
Has Bimba (or any other actuator expert) sanctioned any conditions where a piston is "engineered appropriately" to move the piston faster than 20 inches per second?
Unread 01-02-2010, 13:30
Rule <R71> is quite clear:
<R71> To satisfy multiple constraints associated with safety, consistency, robot inspection, and constructive innovation, no pneumatic parts other than those explicitly permitted by the Pneumatic System Rules may be used on the ROBOT.
The "Pneumatic System Rules" mentioned in the above rule are those listed in Section 8.3.9 "Pneumatic System"
Unread 01-02-2010, 13:56
Electrical Engineer
Rookie Year: 1995
Dick,
This "specification" has been floating around these boards for a while now.
I'd love to find out the exact source of the 20"/sec specification. I downloaded the Bimba manual and can find it nowhere.
I calculate a 1" bore cylinder will move at about 70" per second (unloaded, 45 PSI delta with about a 2 CFPM airflow).
This was brought up in another thread. Upon reflection, my thoughts are:
1. If the cylinder is rated at 125 PSI, I would think it should be built to survive a 110 PSI delta actuation over years of use.
2. The rules state no more than 60 PSI as a working pressure.
3. Assuming that the piston is used to deflect the spring assist at a 45 PSI delta, then the effective contribution of the spring is that of a 45 PSI delta.
4. Added to the 45 PSI delta of the pneumatic system, you have an effective force of 90 PSI delta acting on the piston.
Even with pre-charged cylinders at some percentage extension to maximize speed and direct exhaust at .3 cv, I'm having a difficult time getting a dangerous material fatigue scenario for an expected lifetime of a couple of hundred two minute matches.
Like I said, I'd love to get to the source...
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 01-02-2010, 13:59
boomergeek's Avatar
Ether-
For the engineering rule that the maximum of 20 inches per second for piston speed, can be ignored if the piston is moving in excess of that only when powered by surgical tubing as opposed to when the movement is caused by pneumatic pressure against the piston?
I am a complete novice at pneumatics and I'm taking an educated guess that it's the seals between the piston and the cylinder that are only rated for a maximum speed of 20 inches per second, and my guess continues that it causes excessive wear is independent of whether pneumatic force or elastic force is used to drive the piston to the excessive speed.
Can anyone with knowledge of pneumatic mechanisms explain?
Thanks!
Unread 01-02-2010, 14:04
Chris is me's Avatar
AKA: Pinecone
Just to be clear because someone sent me an email about it and I didn't see it in the thread, you can use surgical tubing in tandem with pneumatics (i.e. a surgical tubing power kicker pulled back with a piston), but you can't use surgical tubing to store compressed air (eg, it's not pneumatic tubing). Just in case anyone was confused, sorry if it's obvious.
Unread 01-02-2010, 14:15
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
If you are worried about the piston breaking itself because it hits the end stop to hard to many times then Bimba does sell pistons with adjustable air cushions at one or both ends.
Bruce
Unread 01-02-2010, 14:21
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by Mike Betts View Post
Dick,
1. If the cylinder is rated at 125 PSI, I would think it should be built to survive a 110 PSI delta actuation over tears of use.
Regards,
Mike
Mike,
I'm not sure that that 'spec' is actually a spec, but instead is a 'recommendation' from Bimba.
Additionally, the speed of the cylinder is not an issue. What is an issue is the impact on the endcap of the cylinder. Consider that some teams are using upwards of a 2 pound mass on the end of a 8-10" lever and accellerating that to 50 ips and you have some serious forces trying to unseat the endcap of the cylinder.
My suggestion to all teams that are using this type of system (including elastomer assist) is to have a hard stop on your robot so that the cylinder does not 'bottom out' against the endcap.
___________________
- Tennyson, Ulysses
Unread 01-02-2010, 14:27
boomergeek's Avatar
Bruce
Actually I'm worried that the 20 inches per second piston speed has been claimed (by multiple persons posting to CD) to have been given from Bimba Customer Support representatives.
As far as I know, no one with any expertise has stated equivocally under which conditions that it is SAFE to ignore 20 IPS guide on piston speed.
I typically choose to considered it likely to be deemed unsafe by thoughtful robot inspectors unless an expert vouches for the SAFETY of the configuration.
If leaving a piston attached to a "bow" when shooting an arrow is an engineering acceptable use of pneumatic piston, will someone with expertise in the failure modes of actuators please confirm?
Surgical Tubing spring rate? Tom Line Technical Discussion 9 30-01-2011 14:33
Surgical Tubing? rogue5n1per Kit & Additional Hardware 1 19-01-2010 22:05
How do you connect surgical tubing? Marlfox Technical Discussion 7 17-01-2009 15:19
[OCCRA]: Surgical Tubing iwanttodunk OCCRA Q&A 1 07-10-2008 06:28
Surgical Tubing punky2k1 Off-Season Events 1 24-10-2001 20:58
