Go to Post We're basically using a two step process: 1. Smoke 2. Mirrors - Tom Bottiglieri [more]
Unread 27-01-2010, 22:41
wolvesrobo wolvesrobo is offline
FRC #1780
wolvesrobo is an unknown quantity at this point
camera????
can anyone help my team out we got some things moving finally and are trying to to figure how to mount the camera to 2 giros so it can spin up and down and also side to side. can you help by chance??? thanks
wolves robotics
Unread 27-01-2010, 22:45
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: camera????
This document shows the assembled Camera Pan/Tilt Assembly with labeled parts. If you have any specific questions regarding assembly feel free to post them.
Unread 27-01-2010, 22:47
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: camera????
You need to have a look at this pdf: http://usfirst.org/uploadedFiles/Com...t_Assembly.pdf
Unfortunately there are no step by step instructions so you'll just need to go from what you see on the 2nd page. Make sure you examine the diagram carefully. (not all the parts are listed)
Thanks,
timytamy
PS:The two "gyro" are actually called servos
EDIT: Vivesrock beat me, but the links are the same
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 30-01-2010, 07:11
JonM JonM is offline
FRC #3141
JonM is an unknown quantity at this point
Re: camera????
We are having another camera issue someone may be able to help with. We need a password to get access to the camera. When the files start to load it hangs due to comm error then the camera goes to the logon window and asks for username and password. Please help
Unread 30-01-2010, 09:23
Re: camera????
Is your camera attached to your PC?
I assume so, since the camera doesn't send pop-ups through the cRIO.
Tell us how you have it connected.
Is the back of the camera mounted up against anything?
Try resetting the camera to factory default using the black switch on the back.
Reset the camera by pulling the power, then holding the reset button while plugging the power back in and continuing to hold until you got the orange light around the lens
Unread 01-02-2010, 02:31
timytamy's Avatar
AKA: Tim
Re: camera????
The default user name should be "root: and password should be "pass" (without the quotes) If that doesn't work try reseting it with the small black button on the back and try connecting to it again (default ip should be 192.168.0.90)
If that still doesn't work can we have more details please.
Thanks,
timytamy
Tim W
Sydney, Australia
Unread 01-02-2010, 10:00
bcieslak
Posts: n/a
Re: camera????
What code are you using to run the camera...We can't seem to get ours to stream video to the driver station. We tried the cameratoDashboard example But that had a ton of compile errors..once we cleaned those up we could download but not get any video...We tried both the axiscamera.h file and the the axiscamera2010.h files in our program but no luck. We noticed that the code for the trackingdemo compiled without any problem but the code so different from the cameratodashboard example we are having a hard time translating...Can anyone steer us in the right direction?? I am sure it is something obvous that we just aren't seeing.
BC
Unread 04-02-2010, 14:17
CrashOverride's Avatar
CrashOverride CrashOverride is offline
FRC #1831
CrashOverride is an unknown quantity at this point
Re: camera????
BC
Initially we had problems getting the 2010CameraDemo in C++ to run, it turned out that the problem was with the driver station. We found that the installer for the required update needs to be run, uninstalled then reinstalled. You will know that the station is updated properly if the Gyro Compass shows up on the display.
Good Luck.
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Tell the difference: 2007 CMU Camera, 2006, 2005 camera? Chris_Elston Programming 2 07-01-2008 13:11
CAMERA Slick Programming 30 10-02-2007 13:30
Camera The yellowdart General Forum 4 21-01-2007 22:56
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
