Re: From C++ to Java
Good, we agree that you don't need to convert the library, but I believe that the translator tool was doing it anyway.
You didn't say what converter tool you were using, or how much robot code you have to convert, so I can't give specific advice. I can say that when WPI students ported WPILib from C++ to Java, they essentially used "cut and paste", then fixed the syntax errors. [They had to do a lot more work on FPGA interfacing, etc, that you don't need to worry about it.]
If you are interested in converting from C++ to Java on your own you need to be familiar with differences between C++ objects and Java objects (C++ objects can be on stack, static memory, or in heap, '.' vs. '->'). Also, the Java version of WPILib all method names begin with lowercase letters.
