Go to Post Real coaches dont use "strategy assistants" during matches. - Rick [more]
Unread 28-01-2010, 04:07
SavtaKenneth SavtaKenneth is offline
AKA: Yotam Kenneth
FRC #2212
SavtaKenneth will become famous soon enough
Re: Can't retract to go under TUNNEL?
That doesn't answer the question, what that one means is that I'm not allowed to make a tiny robot that uses a kicker outside of the frame perimeter that'd still be inside the NORMAL CONFIGURATION.
NORMAL CONFIGURATION – The physical configuration and orientation of the ROBOT when the MATCH is started.
This is the state of the ROBOT immediately before being enabled by the Field Management System
, before the ROBOT
takes any actions, deploys any mechanisms, or moves away from the starting location. This configuration is static, and does
not change during a single MATCH (although it may change from MATCH to MATCH).
That'd mean that you are allowed to retract vertically as this applies only to pre-match configuration. The it may change from match to match section is probably for cases where the team choses to have a hardware switch for which alliance they are on for autonomous mode or something similar.
Tunnel Blockers??? Team 2811 Rules/Strategy 10 23-01-2010 17:36
Tunnel part of Tower GaryVoshol Rules/Strategy 10 19-01-2010 13:20
Tunnel Height JamesByrne General Forum 3 11-01-2010 17:46
pic: Wind tunnel Pat Major Extra Discussion 20 19-02-2009 19:41
Wind Tunnel Wayne Doenges General Forum 48 21-01-2005 19:22
