Re: Camera For Driving?
We are trying to do this as well - video streaming. Currently, we are having problems with lag. I'll be happy to get all the settings you want off the camera but the following is how it's setup to date:
-factory rest the camera (press button for 6 seconds while placing the DC power plug in) -add a 2nd account of FRC/FRC -using 'default code' - interact with the camera (in C++) -it displays to the classmate The students had some lagging of 5-10 seconds. I think it's down to 2 or 3 seconds but in a game, that's pretty bad. All other settings are likely to be the 'factory default' settings. If you can point out any other settings in the camera you modified - that would be great. Also, if you did anything specific on the programming side, that woudl be great to know as well. |
But for your information, we're programming at LV, and the camera's settings that we change was: frame rate, time exposure, resolution and brightness. I can't remember the values by now, but at the night (around six hours) I'll be in the college and we can talk better about this. PS: check your wireless network too. Maybe your band is limiting your comunication. |
For the C++ people out there, TheDominis and I are developing a custom PCVideoServer class that uses a different network protocol and splits up the image for faster display and update. Initial tests show about 20 frames per second. Check it out here:
http://www.chiefdelphi.com/forums/sh...ad.php?t=81158 The downside is, of course, that you need a custom dashboard. TheDominis has provided a test dashboard in C#, and I'm currently working on dasboard software in C++ that will support this type of video feed. It will also have full support for everything else that the provided dashboard has. We're going to check Q & A for the legality of using video code other than what's been provided during competitions. Last edited by slavik262 : 28-01-2010 at 09:30. |
| Java/Netbeans Camera Code for Classmate PC and Axis Camera | joshholat | Programming | 1 | 23-01-2010 14:59 |
| Using kevin's code for driving and camera tracking | razzoc | Programming | 3 | 18-02-2007 08:50 |
| camera code and driving | seanl | Programming | 9 | 16-02-2007 16:21 |
| Problems Combining Camera Code and Driving Code | cmurdoch | Programming | 20 | 10-02-2007 16:34 |
| Driving in Camera Code | wingnut1705 | Programming | 2 | 10-02-2007 11:17 |
