Re: [FTC]: 0.0v on Ext Battery Problem
I missed the post where you said the lights on the controllers were on (I am used to a mix of lighted and non-lighted controllers).
Micheal's suggestion to verify the connection between the brick and the first controller is good. I would expand that to include verifying that all data cables are connected properly (fully inserted and in the correct order). I would also double check that all the power wires between controllers are good also. It may help to put the robot up on blocks, command it to move and then wiggle all wires plugged into the controllers to verify that you don't have a loose connection. |
I will see because i don't know it that the problem because when the battery isn't plugged in it registers OFF when i plug a battery in it registers 0.0v so i think it's a code, firmware, config file, or Template problem because i remember seeing this problem before with RobotC 2.00.
There is a variable that contains the average battery voltage. If you are somehow overwriting that variable, this could be the cause. Have you tried running with an un-modified template?
must say i fixed it, i had the motor controller that had the batttery wired into it not plugged into the first port
| [FTC]: Bluetooth Problem with LabView/FTC Controller Station | James Dowd | FIRST Tech Challenge | 8 | 27-10-2009 10:40 |
| [FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob | PackersFan | FIRST Tech Challenge | 11 | 26-01-2009 21:25 |
| [FTC]: [FTC]: Replacing Fuse for Battery | fqzeng | FIRST Tech Challenge | 4 | 18-11-2008 20:04 |
| [FTC]: First problem with FTC and LabView.....? | PhilBot | FIRST Tech Challenge | 5 | 07-11-2008 10:36 |
| [FTC]: FTC Servo-Motor Problem with Labview | dnhansen | FIRST Tech Challenge | 1 | 26-10-2008 00:43 |
