Go to Post I'm sure there aren't a bunch of rule makers sitting in a board room discussing "What rule can we change now to mess with the teams' heads?" Lets all just sit back and enjoy the regionals! - Rick [more]
Unread 28-01-2010, 08:36
Re: WHAT'S A FAN!?
Ed,
I will get the message out on this issue. Previous years, the fans were at least called out in the wire size and breaker section of the manual. Fans have been viewed during inspections as COTS parts used in their original configuration (unmodified) and used for only for their intended purpose of cooling. Since the electrical rules specify 20 amp breakers as being the smallest allowed, a muffin fan still needed to be powered through this device. Electrical rules in the past of course had allowed all fans to be wired in parallel and fed from one breaker. The majority of easily obtained fans these days in the 12 volt DC flavor, are brushless types. This means that the motor controller is internal and needs no external motor controller. Some teams have used Spikes to turn fans on and off as they saw fit which also was allowed under the rules. Fans used for other purposes, i.e. ball control, need to be powered by KOP motors under all applicable rules.
pic: S.P.A.M fan volcom248 Extra Discussion 4 17-02-2009 09:29
Large Fan Torboticsmember Electrical 7 08-02-2008 08:08
light up fan Dremel Drew Electrical 9 08-02-2007 23:28
Fan Club! TheManTheMyth Chit-Chat 3 29-10-2006 07:30
COOL Fan!!! Murf the Smurf Electrical 4 07-02-2006 20:54
