Go to Post I wonder if the kit motors run counterclockwise in the Southern Hemisphere? - Gary Dillard [more]
Unread 28-01-2010, 09:38
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Re: Black jaguars: not working
ellisk,
I just to confirm where you are...
You are using wind river c++ with "latest" checked out code from firstforge, or the last file release (zip under the file release link)?
You have latest FRC_2CANPlugin.out file from ctr website.
FRC_2CANPlugin.out is in the "ni-rt/system" directory on the ftp server in the cRIO.
ni-rt.ini is modified so that ";FRC_2CANPlugIn.out" is IMMEDIETELY after FRC_NetworkCommunication.out.
Note that FRC_2CANPlugIn.out now should be before FRC_UserProgram (in the past releases it would have been after but that was incorrect, causing all sorts of problems).
And also have you successfully viewed the web dashboard in the 2CAN and have confirmed that the Jaguar ID for your jag is the same one used in the constructor of CANJaguar?
Serial to CAN Gateway in new Black Jaguars? dmcguire3006 Electrical 54 26-01-2010 07:32
Jaguars arent working yoavh360 Electrical 6 19-01-2010 17:20
Victors and Jaguars not Receiving Signal? excel2474 Electrical 1 12-02-2009 16:41
jaguars suddenly not working Mr. E Technical Discussion 1 07-02-2009 21:09
Jaguars working with 2.4 Ghz R/C NOV8R Technical Discussion 0 09-01-2009 16:15
