Go to Post FIRST is about family, making new friendships, belonging somewhere, doing something you love, and finding out what your real love is in life, so when you're old and wrinkly you can look back at high school and say "This is when I found myself." - Winged Wonder [more]
Unread 28-01-2010, 03:42
XD_bring_it's Avatar
XD_bring_it XD_bring_it is offline
AKA: andrew hui
FRC #0115 (Monta Vista Robotics)
XD_bring_it is an unknown quantity at this point
Using the vertical post
This question may have already been asked and answered, but for teams who are using the vertical post to lift their robot, how do you guys plan on aiming your robot. Right now I am having some trouble coming up with ideas to increase the chances of the robot being able to line up and drive accurately to the post to latch onto.
Unread 28-01-2010, 07:20
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Re: Using the vertical post
large opening that narrows down to a smaller....
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 28-01-2010, 09:48
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Yes we are doing it as Drake suggests. Our pole grabber is aligned by a V-shaped interface that allows for a large degree of misalignment. Also our grabber opens up WIDE (>6") to allow for even more misalignment.
Unread 28-01-2010, 09:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
here's one idea
http://www.chiefdelphi.com/forums/sh...ad.php?t=81157
Unread 28-01-2010, 11:52
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Keep in mind that the field is green, with a 2 inch wide stripe running down the middle of it, conveniently straight under the tower. Perhaps you can find some type of photosensor that can detect that line, let you know whey you're lined up correctly over it? Or you could mount the camera to the bot, feed the video back to the driver, and they can use the line as a reference in getting lined up.
All that said, I've found it's important to include as much "slop" as possible in FIRST robots. If something requires you to be in exactly the right position, it's not going to work during competition. The further from "ideal" position you can make it work, the better.
Unread 28-01-2010, 12:05
Josh Drake's Avatar
Engineering Mentor
Works for FLL too
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 28-01-2010, 13:33
Section 6 even specifically states that any given dimension can vary by up to 1/4" and the entire field by up to 4" due to different setup crews at each event. If you can't handle that type of variance, you're doing something wrong.
Unread 28-01-2010, 18:33
baruffir baruffir is offline
Me
FRC #0178 (Enforcers)
baruffir is an unknown quantity at this point
Similar to what Dan said. We have a very large V shape, with a 12" opening narrowing down to grasp the pole. Also, we should have a camera feed to the driver's station to give them a different angle to line up with.
Unread 28-01-2010, 23:45
JB987 JB987 is online now
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Originally Posted by squirrel View Post
Can't help but wonder how the pictured gripper will avoid damaging the pole? Fair to assume some serious padding will be added to the parts that compress the pole?
How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes brreadd Pneumatics 3 20-11-2009 15:35
TwoColorTrackDemo Vertical Sweep vb_master C/C++ 1 08-02-2009 12:50
"Attaching" to the vertical pole. Madison Rules/Strategy 10 04-02-2004 22:59
Vertical bar interaction Madison Rules/Strategy 5 10-01-2004 16:22
vertical conveyor belt ahecht Technical Discussion 3 15-02-2002 16:16
