Re: [FTC]: 0.0v on Ext Battery Problem
There is a variable that contains the average battery voltage. If you are somehow overwriting that variable, this could be the cause. Have you tried running with an un-modified template?
must say i fixed it, i had the motor controller that had the batttery wired into it not plugged into the first port
| [FTC]: Bluetooth Problem with LabView/FTC Controller Station | James Dowd | FIRST Tech Challenge | 8 | 27-10-2009 10:40 |
| [FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob | PackersFan | FIRST Tech Challenge | 11 | 26-01-2009 21:25 |
| [FTC]: [FTC]: Replacing Fuse for Battery | fqzeng | FIRST Tech Challenge | 4 | 18-11-2008 20:04 |
| [FTC]: First problem with FTC and LabView.....? | PhilBot | FIRST Tech Challenge | 5 | 07-11-2008 10:36 |
| [FTC]: FTC Servo-Motor Problem with Labview | dnhansen | FIRST Tech Challenge | 1 | 26-10-2008 00:43 |
