Go to Post It's more of a "gracious professionalism" thing. - Matt Leese [more]
Unread 23-01-2010, 16:52
dona klarson dona klarson is offline
dona klarson is an unknown quantity at this point
MECANUM WHEELS PROGRAMING
hi
i have a problime understanding the concept of mecanums wheels' programing .. i mean there the magnitute .. direction ... which i don't get ....
so please help me ...
dona
Unread 23-01-2010, 19:32
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: MECANUM WHEELS PROGRAMING
Think of a vector. It has a magnitude and a direction. The magnitude is between 0 and 1 how fast to move, and the direction is in degrees. These two parameters are for translational movement. For rotation, you can spin in place or spin and translate at the same time... the range is -1 to 1 for counter-clockwise and clockwise rotation.
Unread 25-01-2010, 09:27
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
These are the important parts to get started. We don't have a chassis yet, but we wired up 4 Jaguars and 4 motors and the motors move as they should:
RobotDrive *mecanumDrive;
Joystick *Attack3Joystick;
mecanumDrive = new RobotDrive(1, 2, 3, 4);	// frontLeft, rearLeft, frontRight, rearRight
Attack3Joystick = new Joystick(1);
mecanumDrive->HolonomicDrive(Attack3Joystick->GetMagnitude(), Attack3Joystick->GetDirectionDegrees(), Attack3Joystick->GetTwist());
The kit of parts joysticks don't have a twist handle so I didn't test the twist (rotation).
Unread 26-01-2010, 11:18
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
I'd assume that GetTwist() gets the z-axis value, which for the KOP joysticks is the throttle at the bottom of it.
Also, this thread is from a year ago, but I created a custom joystick class for use in omni-directional drive trains:
http://www.chiefdelphi.com/forums/sh...ad.php?t=70468
Correct me if I'm wrong, but I believe GetMagnitude() just takes the square root of the squares of the x and y factors of the joystick to get its value (the Pythagorean Theorem approach). This is flawed in that due to special right triangles, sticking the joystick in the corner of its field of motion will generate a magnitude sqrt(2) larger than sticking the joystick all the way to a side. I created my own algorithm which "normalizes" the magnitude of the joystick vector so that it has a max value of 1 all the way around its bounds. Details are in the linked thread.
I wrote the OmniJoystick class before I knew about function overloading and inheritence, so to make life simpler you can change GetAngle() and GetR() in the my code to GetMagnitude() and GetDirectionDegrees() if you'd rather use the "official" function names.
Unread 27-01-2010, 22:50
Originally Posted by slavik262 View Post
Correct me if I'm wrong, but I believe GetMagnitude() just takes the square root of the squares of the x and y factors of the joystick to get its value (the Pythagorean Theorem approach). This is flawed...
I could be wrong, but I don't think your code is optimum for a mecanum drive. Looking at the WPI code, nor is that.
If I push the joystick all the way to the right and forwards, the magnitude is 1.414 and the angle is 45 degrees. (maybe it's -45 degrees with the joystick defaults, but the idea is the same). If those magnitude and direction values are entered into the HolonomicDrive method, the inference is that I want to move forwards and to the right at 100% speed for both, so all wheels get 100% power with appropriate direction for each to make the chassis move diagonally as fast as it can. Looking at the WPI HolonomicDrive code, that's not what I get:
void RobotDrive::HolonomicDrive(float magnitude, float direction, float rotation)
	magnitude = Limit(magnitude);
float RobotDrive::Limit(float num)
	if (num > 1.0)
		return 1.0;
	if (num < -1.0)
		return -1.0;
	return num;
If the joystick is moved far right and forwards, the HolonomicDrive method gives only 71% power (100%/sqrt(2)) to each wheel because it limits the magnitude to 1.0. That's not what I expect or want. Each wheel should be getting 100% power. It's not a big deal because I don't expect to be running the robot at full speed during this game and the difference between 71% and 100% power when moving diagonally is not something to go crazy over.
Unread 28-01-2010, 05:01
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
We do not use the code from WPI. I and my students have written our own. We did this so they understand how it works. When carbbing the opposite corners move in the same way. When turning the sides move together.
You the function below once for each wheel to get the wheels power. It works very well and is easly understood. It assumes that forward is 1.0, back is -1.0, crab left is 1.0, right is -1.0, turn to left is 1.0 and right is -1.0.
The joystick values are assigned when we read in the DS values. They may need to be reversed via negation. We also may need to negate again when we assign the values to motors. (left vs right side)
Right now the rotation seems backwards and may be the result of us switching front to back but for now it works great.
We do it this way so we can use the same code in autonomous. We just pass in the values we want in the auto code and it all works great.
float LC2010::GetMecanumPower( int i_wheel, float f_direction, float f_power, float f_turn )
	float retValue = 0.0;
	switch( i_wheel )						// Apply Forward and side motion
		case LC2010::kMecanumLeftFront:
		case LC2010::kMecanumRightRear:
			retValue =  f_power - f_direction;
			break;
		case LC2010::kMecanumLeftRear:
		case LC2010::kMecanumRightFront:
			retValue =  f_power + f_direction;
			break;
		default:
			printf("GetGetMacannumMotorValue: Bad Wheel passed....\r");
			break;
	switch( i_wheel )						// Apply the rotation
			retValue += f_turn;				// retValue - f_turn;
			break;
			retValue -= f_turn;				//retValue + f_turn;
			break;
		default:
			printf("GetMacannumPower: Bad Wheel passed....\r");
			break;
	if( retValue < -1.0) 								// condition before recasting to unsigned char
		retValue = -1.0;
	if( retValue > 1.0 )
		retValue = 1.0;
	return retValue;
Unread 28-01-2010, 11:52
Originally Posted by pafwl View Post
We do not use the code from WPI....
See post number 9 in the following thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=81025
Unread 28-01-2010, 16:13
I took a closer look at the WPI HolonomicDrive code. If the joystick is pushed full forwards (magnitude 1.0, direction 90 degrees) the drive wheels get only 71% power due to the sin and cos of (direction+/-45degrees) functions. The WPI code trades off maximum power for directional control, which is certainly a valid solution but I have a different strategy
Unread 28-01-2010, 16:42
I think you can have your cake (max power) and eat it too (correct direction), by using the scaling technique suggested in post number 9 in the following thread:
Unread 28-01-2010, 18:21
This has been updated in WPILib and will be in the next update.
Unread 28-01-2010, 20:29
What does the pronoun "this" refer to?
Which post are you replying to?
There's no context, so it's not clear.
Thanks.
Unread 29-01-2010, 01:03
Here is the change list description:
+ Add a Cartesian implementation of the mecanum drive method.
* Clean up the expressions in the polar mecanum drive method.
* Replace the saturation approach with a normalization to prevent inconsistent wheel speed ratios.
* Scale the magnitude by sqrt(2) to get full power along the axes.
Unread 29-01-2010, 01:10
Great work! Except now our robot won't have a power and pushing advantage over the other mecanum's using HolonomicDrive, LOL.
Unread 29-01-2010, 01:16
The approach suggested in post number 9 in the following thread:
suggests scaling by the largest magnitude when any magnitude exceeds 1, rather than scaling by a fixed scalar (ie sqrt(2)).
the reason for doing so is explained in the post.
your thoughts?
Unread 29-01-2010, 01:18
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
<baited_breath> So when do we get this next update you speak of? </baited_breath>
Can you just commit the RobotDrive changes to FIRSTForge? We would be happy to help test.
Mecanum Wheels? Maxpower57 Kit & Additional Hardware 17 17-03-2008 16:50
Mecanum Wheels Calvin_1631 Motors 7 09-02-2007 13:29
4 encoders + mecanum wheels programing Smoking_Gun Programming 4 18-01-2007 23:43
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
