Go to Post Right, play to win. Play to win the event or play to win one match? This year, unfortunately, they are not the same thing. - Paul Copioli [more]
Unread 27-01-2010, 21:22
Matt2081's Avatar
Matt2081 Matt2081 is offline
Software Mentor, Alumn
AKA: Matt Birkel
FRC #2081 (Icarus)
Matt2081 is on a distinguished road
Question Customizing the Dashboard
I was wondering, is it possible to customize the dashboard (remote, local, or both)? If so, how do you do this?
2011 Boilermaker Regional Winner
2011 Boilermaker Motorola Quality Award Winner
2010 Boilermaker Regional Finalist
2009 Boilermaker General Motors Industrial Design Award Winner
2008 Boilermaker Engineering Inspiration Award Winner
2007 Boilermaker Rookie All-Star Award Winner
Unread 27-01-2010, 21:23
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Re: Customizing the Dashboard
I think that you need exactly this: http://www.lvmastery.com/TipJar2009-02-10
Unread 27-01-2010, 21:45
Matt2081's Avatar
AKA: Matt Birkel
FRC #2081 (Icarus)
This looks great! I'll try it tomorrow. Thanks a lot!
Unread 27-01-2010, 22:56
joshholat joshholat is offline
FRC #0930
joshholat is an unknown quantity at this point
Is there any way to alter this using Java as our development system? Does Java provide a way to interface with the Driver Station Dashboard?
Unread 27-01-2010, 23:27
Have you looked at the Dashboard class?
Unread 28-01-2010, 00:45
FRC #0930
Yeah, I'm aware of that. I guess I should of clarified. I mean is there a way to more so interact with the GUI objects such as the gauge and various graphs. Or is that all in there? From what I can tell, the Dashboard class seems to be just for text stuff.
Unread 28-01-2010, 12:07
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
The dashboard class will just populate the data being sent to the dashboard program. I don't have the Java apis, but the C++ apis have things to add just about any data type that you want (signed/unsigned int 8,16, 32, float, double, bool, string). Additionally it lets you organize the data in arrays and clusters.
The dashboard program has a large cluster on the left side of the diagram that needs to match what is being sent over. Once that matches, you can read out of the cluster to populate gui items.
I would suggest pulling up the default robot side code and look for where the dashboard data is populated. Then pull up the default dashboard program and see how the cluster corresponds to the way the data is filled in by the robot. Once you understand that, you can do whatever you want with the data once it is read from the socket.
Unread 28-01-2010, 12:19
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
I heard that there would be a JAVA dashboard but I haven't seen it yet.
Unread 28-01-2010, 14:38
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
I'm making a customizable dashboard with drag and drop custimization. It's going to be extremely user friendly, run in C++ (so you have maximum speed and response time), and work with all three robot code configurations (LabVIEW, Java, and C++).
http://www.chiefdelphi.com/forums/sh...ad.php?t=80561
Unread 28-01-2010, 20:25
Matt2081's Avatar
AKA: Matt Birkel
FRC #2081 (Icarus)
I watched the blog, and it summarized very well how to modify the Dashboard, but it looks as though it is only modifying the remote Dashboard. How would I modify the local Dashboard (the one on the classmate)? Can I do that?
Also, is the drag-and-drop customizable Dashboard going to have the capability to modify the local Dashboard?
Unread 28-01-2010, 20:41
sloteera's Avatar
AKA: Rafa
You just need switch your dashboard remote customized by the local dashboard.
You'll need to create a new application of your new Dashboard (right click in Build Specifications), then you'll choose yours files to include in application and save all with "Dashboard. x " name (i.e Dashboard.exe, Dashboard.ini..).
You'll see a new folder containing three files. You'll need to go at C: > Program Files > FRC Dashboard and switch the older files by the newer files!
When you open your driver station, automatically your customized dashboard will be loaded!
I hope that you can understand me
Unread 28-01-2010, 20:45
sloteera's Avatar
AKA: Rafa
I forgot: the directory C: > Program Files > FRC Dashboard you'll need to open in Classmate!
Unread 28-01-2010, 21:44
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
If you're running C++ or Java, some of the examples have a DashboardDataSender class. That should send everything on the robot. If you want to change the dashboard you need to change that class to match it. Best if the programmer knows both C++ and LabVIEW
LabVIEW Video Tutorial: Customizing The FRC Dashboard To See Your Data LVMastery NI LabVIEW 0 10-02-2009 13:50
The perfect dashboard Joe_Widen Programming 4 19-06-2006 01:34
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
Code for the Dashboard HuskieRobotics Programming 1 04-03-2004 11:10
