Go to Post You are becoming the leaders of tomorrow by leading today. - Chris Fultz [more]
Unread 28-01-2010, 12:25
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Re: Possible to Adjust Speed
Originally Posted by Wayne Doenges View Post
What if you used a servo that will turn CW or CCW without stops? You could use a piece of tubing to match the servo output and the flow control knob.
Not sure of this year's rules regarding servos. (CAN you use stronger ones THIS season, or continuous rotation servos? You couldn't in previous years.)
Bear in mind that the kit regulators take a LOT torque to turn. Probably way too much for the basic kit servo.
Now you CAN easily make a servo in software with a pressure regulator, a window motor, a 10-turn potentiometer, and TWO pressure transducers (1 for output, 1 for SYSTEM pressure, to make sure you CAN reach it before trying).
In addition to a simple closed loop servo routine in software, you also need to do a few other things:
(a) put both software limits to the pot AND a mechanical friction/slip clutch between the motor and the pot/regulator set, to keep from breaking either one should the motor or software go crazy and attempt to turn it too far in either direction.
(b) monitor the full system pressure as well, to disable the servo routine when the system has insufficient pressure. Otherwise, you will "polarize" the servo wide open, trying to get it to a setting you simply can't reach.
But there are simpler methods.
Example - Create a Buffered Supply Tank, at any programmable pressure.
Use a center-blocked valve (or a pair of kit valves), two flow regulators, a pressure transducer, one Clippard tank, and software. Software is similar to the compressor routine. In this case though, whenever it is out of range EITHER way, pulse one or the other valve coil to either fill or drain the tank until it reaches the desired pressure.
One flow regulator controls the tank FILL rate (NEARLY wide open), while the other controls the BLEED-OFF (probably a fairly low setting, to prevent TOO much air waste from a user's "setting indecisions" ). A software variable now determines the tank's desired "set" pressure, and it "automagically tracks it".
Simpler: Monitor the cylinder's pressure with a transducer. When the cylinder reaches the desired force, just cut off its supply! (Again, use a center-plugged [center-off] valve.)
FYI, a center plugged valve is one of the order options for valve parts in the familiar KoP SMC SY3000 series. See the SMC datasheets for more info.
Does this make sense?
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Is it legal to adjust CIM's timming? Capt. Quirk Motors 6 16-01-2008 07:35
Wheel Speed Sensors / Vehicle Speed Sensors chitu Technical Discussion 11 12-01-2008 02:46
Possible to do multi-speed transmission with v-belt? Squirrelrock Motors 15 13-12-2005 14:44
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
