| Thread Tools |
Rating:
Display Modes |
Set computer to receive it's IP via DHCP?
On page 45.... in Section 1... of the Control System Manual it says, "set your computer to receive it's IP via DHCP". How do we do this?
Re: Set computer to receive it's IP via DHCP?
The DHCP settings are reached by going into your Network Connections -> Local Area Network Connection (right click)-> Properties -> TCP/IP
I hope this helps. This is also where you will set the static IP. |
OK- We have been there and set our static IP to 10.21.47.6 (our team # is 2147). Is their something we have to select to set the DHCP? I don't see anything referring to a DHCP in any of these screens?
Set it to obtain IP address automatically. DHCP is the protocol by which it does that.
Thanks! That did the trick.
I have some trouble with that too..
I set the ip to get automatically and then open internet explorer and type in 192.168.1.250 as described in the manual. Yet I cannot connect to the bridge... Here is how the wires run The cisco modem(wrt610n) is connected to the computer through ethernet cable. Then the ethernet cable from the linksys modem(wga600n) is connected to the cisco modem. I don't know what the probem is so can anyone help? Thank you for any kind of help. |
#7
I belive you need to connect to the bridge wirelessly to be able to use it. 2 DHCP servers wired directly together is not the best idea in the world
#8
Also, the 2 ethernet cables into the bridge have to be plugged into the "1,2,3, or 4" Ethernet jacks, not the jack labeled "Internet". |
#9
I tried it it but still it does not work..
In the manual is says type 192.2689.1.250 and we tried it but id did not work.. Realizing that that it may be a defaut setting we connected the brigde(wga600) directly to the computer and ran ipconfig on command propt, got the ip and default gateway, ran them on a web browser but it still did not work.. we cannot connect to the bridge... Any suggestions??? |
#10
Sorry for a double post but the ip was 192.168.1.250..
it was little typing error |
#11
Try connecting your PC directly to the WGA600N via Ethernet cable.
Set a static IP on your PC of 192.168.1.6, netmask 255.0.0.0 Then try browsing to 192.168.1.250 |
#12
We already tried...
#13
Did you disable your PC wireless if you have it?
#14
Im having trouble with browsing the bridge. We got into the configuration page and did all the steps like rebooting but now when we try to get to the configuration page again, it says connection was reset. What do we do.
#15
Did you change the bridge IP address when you rebooted it?
Did you then change your PC's IP address to be compatible with the new bridge IP address before you tried to reconnect? That's the most common snag. I presume you are hard-cabled from the PC to the bridge while doing this, or are you going through the router too? |
| Batch files to switch between DHCP and Static IP | DtD | Programming | 9 | 28-01-2010 14:27 |
| changing code after it's set to run at startup | smcmahon | NI LabVIEW | 4 | 11-02-2009 19:36 |
| How many IR Boards did you receive? | SpaceOsc | General Forum | 3 | 22-02-2008 16:17 |
| pic: It's a bird.. It's a plane.. It's the 573 Mech Warrior bot! | Lisa Perez | Robot Showcase | 3 | 27-02-2005 15:09 |
| NJ Regional - Anyone like to receive us? | Chuck[#1156] | Regional Competitions | 27 | 03-03-2004 02:58 |
