Go to Post Bring 'em on, kiddies. You underestimate the power of Amanda Morrison. - Amanda Morrison [more]
Unread 28-01-2010, 11:21
alex33zebras alex33zebras is offline
FRC #2909
alex33zebras is an unknown quantity at this point
Hanging Mechanism Material
My team was looking at 2004 competition videos, and we have decided to try a technique used in one of them, but we need a material that is flexible enough to bend at least 90 degrees, and that also can suppurt a 15 lbs. hook. If any material like this exists could someone help me out and let me know what it is?
Thanks
Alex
Unread 28-01-2010, 11:38
FRC #2909
My team was looking at 2004 competition videos, and we have decided to try a technique used in one of them. The idea is to use some sort of pole whether its fiberglass or another material, that can bend in half by bieng pulled down by a cim motor, and is released during the last 20 seconds until the hook is flush with the bar. Then we use the cim motor to retract the rope and pull ourselves up. but we need a material that is flexible enough to bend at least 90 degrees, and that also can suppurt a 15 lbs. hook. If any material like this exists could someone help me out and let me know what it is?
Thanks
Alex
Unread 28-01-2010, 11:48
Re: Hanging Mechanism Material
Rope?
Unread 28-01-2010, 11:52
sunnyboy780 sunnyboy780 is offline
FRC #0020 (The Rocketeers)
sunnyboy780 is an unknown quantity at this point
No, not rope... I think he means something flexible, but able to stand up with 15 pounds on it. We tried making a folding arm with a spring in the middle, not sure how well that will work.
TEAM 20
- 2009 BAE Granite State Regional Finalist
- 2009 UTC Connecticut Regional Judge's Award Winner
- 2008 Rochester-Finger Lakes Regional 1st place
- 2008 Boston Regional 1st place
Unread 28-01-2010, 12:19
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Thanks
Alex
I can't give you a definite answer, and this is what I had originally suggested to my team, but I think something like steel cable should be able to do what you want. Although I also suggest you try to use something different for your hook, 15 lbs sounds a little ridiculous, you should be able to find something much lighter. Last I checked our hook device weighed less than 2 lbs, what is the reason your using something so heavy?
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 28-01-2010, 13:31
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Basically, what you're looking for is something that works exactly like a fishing rod does - it flexes when pulled, many can even completely double over before breaking. Yet at the same time it provides sufficient spring to snap up straight when the force is released. The key is finding a rod with the proper strength to be straight with your hook, yet flexible enough to bend over backwards.
I would suggest your search for material starts there, in an industry that has pretty much already perfected what you're trying to do.
Unread 28-01-2010, 13:37
Even 330's 2004 hanging device wasn't 15 lbs... Maybe it was if you included the arm on top, and the upper stage of the lift! And that hook was solid Al, with a van door motor, a 1:1 gearbox, and a metal roller included... It was overkill, but it worked.
You're sounding like extreme overkill. Start with a lighter hook.
Unread 28-01-2010, 13:45
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
See also the threads discussing stored energy during inspection period as they relate to kickers. You can understand an inspector's trepidation at seeing a large pole bent double inside his volume-measuring box.
Pinning a Mechanism Rob2713g Technical Discussion 5 30-01-2008 13:11
Arm mechanism team 2191 Technical Discussion 13 24-01-2008 07:15
Extension Mechanism acer_7 Technical Discussion 31 09-06-2006 18:02
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
