Go to Post The magic is ALL in the mentors. - AdamHeard [more]
Unread 28-01-2010, 14:08
Noamr Noamr is offline
FRC #1574 (Miscar)
Noamr is an unknown quantity at this point
Data Acquisition
Hello,
I was wondering how I should time my sensor loop in the Timed Tasks VI. What timing is good for what sensor?
I know I should RTFM but I really couldn't find the info on the sensors' manuals.
Thanks,
Noam
MisCar 1574
Unread 31-01-2010, 00:04
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: Data Acquisition
Originally Posted by Noamr View Post
Hello,
Thanks,
Noam
MisCar 1574
I assume you are referring to the Periodic Tasks.vi, which has an icon that says "Timed Tasks" (go figure ). Anyway, it really depends on what sorts of sensors your team is using and what you're using them for.
If for instance you are using a sensor (say a gyro or rotary potentiometer) to feedback into a PID control, you probably would like a fairly quick update and could put it into the 20 ms loop. If you want a different loop rate, there's no reason why you couldn't change the hard coded values to some other rate.
There are no hard and fast rules to what you should do. Basically, if you need the faster response/rate then use it, but if not, you can save the CPU cycles for other things.
Designing a Data Acquisition System orionteo Chit-Chat 0 29-11-2007 01:38
NI LabVIEW and Data Acquisition Pilot Program 2006 Application Ready! Danny Diaz National Instruments LabVIEW and Data Acquisition 2 18-10-2006 15:55
National Instruments LabVIEW and Data Acquisition Forum Danny Diaz National Instruments LabVIEW and Data Acquisition 1 16-01-2006 13:20
Autodesk's Acquisition of Alias Ryan Dognaux 3D Animation and Competition 7 05-10-2005 18:12
