Go to Post "You fogot the gears!!!!" - The_Gman [more]
Unread 28-01-2010, 15:04
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Limit switch to solenoid problem
How you hooked it up is key here. It sounds to me like you may have wired the limit switch to short power and ground - this is bad. The Digital Sidecar contains an internal pull-up resistor on the digital IO ports - this means if you send no signal to the input, it will read as if 5V was sent. See page 19 of http://usfirst.org/uploadedFiles/Com...Rev1_enc .pdf
To wire a limit switch, take a standard PWM cable and wire the Black and the White wires to the switch in your preferred method (normally closed or normally open). The method used doesn't really matter - normally closed means you would see a 0 in the code when the switch is not pressed, a 1 when it is pressed. normally open is reverse. Do NOT hook up the red wire from the PWM. It's not needed (due to the pull up resistor), and if you mess up your wiring you could risk shorting it. It's better all around not to use it with the limit switches.
Limit Switch problem Zellboy Programming 5 12-02-2009 19:38
Limit Switch Problem Boydean Programming 3 13-02-2008 16:32
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
limit switch wedellm Electrical 4 16-02-2007 13:01
